The black plastic version is not an "old version", it is just a different version. Some here say they prefer the metal version, but you can be sure the gap in SQ is for sure not as big as the price gap between both versions. And maybe you would even prefer the black version. What somebody else xonsiders "better" must not necessarily match with your preferences.
thebit Opus#1 DAP from South Korea
- Thread starter CosmicHolyGhost
I totally agree with your statement, there's only 2 major changes a CNC body and an upgrade Op amp. There's not a lot of review comparing the 2.. and I can't find an official statement from the manufacturer on the upgrade maybe I search it wrong..
down to 329 USD incl, the leather case at MusicTeck. They really want me to order it...
lotech
- Sep 26, 2013
at $329 it's an absolute steal. for the money you can't go wrong.
Oh trust us that there's indeed a Metal version of the #1. theBit is not as active in marketing it as compared to other brands. Plus only 500 units where ever made of the Metal version. So if you're looking at a touch of exclusivity, then the Metal version is for you.
majo123
- Jan 1, 2016
I agree. I couldn't be more happier with my opus 1 , i debated with myself for a couple of months to buy or not and realy glad I did in the end.
- Oct 6, 2013
where did you see $329? I only see $359, unless there is a coupon or some other discount?
BrianD19
- Mar 11, 2017
Does the Opus work with Win 10?
I have a laptop on its last legs running Windows 7 that keeps shutting itself down so I plan on replacing it this week, probably with a machine running Windows 10.
parabellum777
If you are refering to the USB DAC function of OPUS#1, it does not work properly either with Windows 10 or with Windows 7. Windows 10 has problems detecting it (Windows 7 has not this problem), and with both the sound is cut for a second periodically after some strange clicks. I ended up buying an OPPO HA-2 to use with my computers, and all my problems have been solved.
My apologies: I overlooked 329 was for a "used, like new" unit from MusicTeck via amazon. So best price for new unit is still 359. Which is still not bad!
- Jun 22, 2015
$329 is for a used one from MusicTeck on Amazon.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Still £429 on amazon uk! Where are our deals dammit ?!?
tienbasse
- Dec 5, 2011
Please DO forget the remote possibility of ANY good deal in Europe.Still £429 on amazon uk! Where are our deals dammit ?!?
It's cow-milking land after all, where all major brands make distributors sign supply agreements to prevent any significant rebate.
majo123
- Jan 1, 2016
To all you uk guys musictek will ship to uk.
so with import taxes Should be around 300 pounds .
What a steal!
I paid the UK amazon price just in case I didn't like it
Wish I had known how much I would like it, would of saved a he'll of a lot.
What a steal!
Tell me about it...local retailers here are tooooo slow to adjust pricing (similar scenario in Singapore).
The #1 and Mojo are good examples where in local retails fail to mirror the current price offerings of the Manufacturer.
Total: 12 (members: 0, guests: 12)
