Was wondering also if anyone can compare the balanced on x7/am3 to opus1.
Thanks .
I used/use balance on both units - i find the #1 more enjoyable/musical to listen to. Not as fatiguing as compared to the X7.
Thanks .
captblaze (or anyone else that can help),
I just bought an Opus #1 and saw your comment about using Line Out to your car stereo. I assume you are talking about the Balanced output jack. I'm confused on what type of cable to buy for the setup you're talking about.
Could you point me in the right direction?
Thanks!
the 3.5 mm jack is the line out. I connect from that jack to the aux input on my car stereo. once connected I drop down the menu and activate the line out toggle. by doing this I bypass (or lock out) the volume control and it is set to maximum. make sure you have your car stereo volume set low to avoid getting an awful blast of sound. remember to connect first and then set the line out toggle.
occasionally it will falter when changing from one album to the next, but it infrequent and re toggling the line out corrects that issue
Is the Balanced Output jack, then, only used for Balanced Headphones?
I had a first long listening session using 2.0.3 firmware, and then 2.0.5, and to my taste, it is a significant improvement into the "natural/fatigue-free" direction, while not sacrificing the high level of details and wide soundstage that characterizes this DAP.
Treble in 2.0.3 are quite forward and a bit too dry to my taste, cymbals have a very fast decay which doesn't sound very natural. But they are advantages like good clarity and extreme extension, but this can get very tiresome with IEMs already having bright treble (typically my Fidue Sirius become very aggressive in the treble with this firmware).
Bass in 2.0.3 are quite strong and impactful, which I like very much, but combined with bass-heavy IEMs (AK T8iE, Rose Capp MK2), this is a bit too much. Mids are a bit backwards compared to other DAPs (Cayin N5, FiiO X5-iii, LG V10), which bothered me when it comes to vocals and guitar. This was OK with the Sirius but again not so much with warmer IEMs.
When I switched to 2.0.5, there was a small decrease in bass (but still great), a big step forward for mids (vocals/guitar became really nice and distinct from the rest), a nice step backwards for treble with slower decay (although it could be a micro-touch slower for rendering even more realistic cymbals).
Overall, what impresses me the most with this DAP is the soundstage (very wide, especially in balanced mode), which is on par with Cayin N5 and wider than X5-iii (balanced output doesn't seem to help X5-iii as much as N5 and Opus #1). Detail retrieval is also extremely good (slightly superior to Cayin N5 and and very slightly superior to FiiO X5-iii). Background noise is very low, unlike N5 in balanced mode.
I'll spend more time with this little toy, but so far, it is a VERY pleasant experience, and the UI is by far the easiest to master that I have seen since the AK120, which is impressive. It took me less than 5 min to explore it, and even the old UI (my Opus came with a pre-Lollilop firmware) was already nice, despite the "difficult" EQ.
How many hours do you have on #1 so far? Give it about 100hrs of burn in before drawing the final conclusion
Begging your pardon, but I would like to add my video review of this fine piece of kit. I really enjoyed my time with the borrowed unit. Thanks @nmatheis
. This really is a grand DAP, and one I will be looking for in the future. Love the sound, simple to use and just an all-around top unit. Outstanding job, theBit.
