USB DAC is enabled in settings, of course?Hoping someone see's this and has a fix or my DSDs is toast. DAC Mode does NOT work. I've flashed .5c & .5d firmware and no iOS/Mac OS/Windows will see it as an audio device. Plays music from the SD Card. Thoughts
The Zishan dsd's corner
twopedalwarrior
Thanks for the reply, and it is. And of course I just fixed it with a new cable. The old AtoC cable was charge only, not data. In this day and age I should not be surprised that two different types exist.USB DAC is enabled in settings, of course?
buzzbuzz
- Dec 21, 2016
Flashing is done by putting the firmware file on the root directory of the SD card. Then power up. Once it done. Take out the SD and delete the firmware file.Hoping someone see's this and has a fix or my DSDs is toast. DAC Mode does NOT work. I've flashed .5c & .5d firmware and no iOS/Mac OS/Windows will see it as an audio device. Plays music from the SD Card. Thoughts
InvisibleInk
Gee, inflation has kinda gotten outta control, huh bros?
Ben86
- Jun 24, 2015
Ben86
- Jun 24, 2015
It is time to bring new Zishan with akm4499ex to the light
avitron142
- Nov 2, 2013
never had a problem with the WaZe FB group
tends to be mostly about hacks with the walnut and earlier Zishan Z1-3 models not so much on the DSD.
David B is an actve member.
Lots of info on opamp rolling and accessories.
Again not so much emphasis on the DSD or T1 series
Does anyone have a spiritual successor to the Walnut V2? It's not in production anymore and literally impossible to source a V2S even second-hand.
What's the newest DAP that has a more analogue-like sound - does Zishan have one? The Z1 sounds more crisp/analytical (less analogue) to me.
DBaldock9
In searching AliExpress for "portable mp3 player", I don't see any of the type of less than $50 devices that can be easily opened for op-amp rolling.
There appears to be some $80 - $120 Zishan and F.Audio devices that look similar to the V2S, but they have display screens.
Everything else has a more sealed, phone-like design.
Zishan Z5 is the latest model. Available on AliExpress.
Just found this amazing item on AliExpress. Check it out! US $191.76 32%OFF | Newest Zishan Z5 Portable OPA1622 HiFi MP3 Player Amanero Digital Turntable DSD ES9039MSPRO Bluetooth 5.1 DSD Balanced Output
https://a.aliexpress.com/_EzXj0Uz
Ben86
- Jun 24, 2015
No more option to chante stock OP-AMP?Zishan Z5 is the latest model. Available on AliExpress.
Mr.HiAudio
Member of the Trade: RIOBuds
Since from Z4No more option to chante stock OP-AMP?
But at least it has WiFi and there is a side load android app that you can control it.No more option to chante stock OP-AMP?
DBaldock9
They are using a good op-amp in the TI OPA1622 - but it's a surface-mount VSON-10 package, rather than a 8-pin surface-mount or DIP package.
Mr.HiAudio
1622 replaced to cheap rt6863dhey are using a good op-amp in the TI OPA1622
232tomas232
this is sad. they chose a good DAC chip. but the output part is likely to spoil everything. if there is free space inside, you can integrate a separate board with the output stages.1622 replaced to cheap rt6863d
