The Zishan dsd's corner
May 3, 2021 at 9:17 AM Post #3,391 of 3,717
Probably the problem is in the card reader. I had it more like it, I soldered contacts
For firmware - write to the seller, they can find the firmware without any problems
Thanks, I have contacted NiceHCK and they will try to get firmware 0.5d from Zishan.
When the player is working again, and the stuck song problem is still there I will check the cardreader and other soldered connections.
May 3, 2021 at 9:28 AM Post #3,393 of 3,717
Can I place caps same as Your DSDs sabre?
If you want to get an interesting sound, then I drew a mod.
* the picture of the player is not mine
May 3, 2021 at 9:29 AM Post #3,394 of 3,717
May 3, 2021 at 10:51 AM Post #3,396 of 3,717
Does anyone know if 0.5d firmware version is applicable to DSDs AK4499 version?
I have 0.5c installed on mine.
May 3, 2021 at 10:56 AM Post #3,397 of 3,717
Results from several mods posted
The 275 has pretty poor bass control. I would replace it with something faster. AD8620 or ADA4898-2
May 3, 2021 at 11:02 AM Post #3,398 of 3,717
@maxifuny
Thank You so much for this scheme!
This Wima is ok for audio?
WIMA Red 5% 63V 100-330nF
I see this is nF not uF on your scheme :wink:
Can I place electrolytic polarised caps in parallel to this ceramic (unipolar)?
For example 470uF 10V ELNA or 100uF 16V Nichicon?
@edit
Safe placement without overburning looks like that:
May 4, 2021 at 12:58 PM Post #3,400 of 3,717
For example 470nF 10V ELNA or 100nF 16V Nichicon?
is it possible to use Wima? - Yes.
Is Wima capacity correct? - Not! It is important
470uF 10V ELNA or 100uF 16V Nichicon - for example. Not "nF" !
May 4, 2021 at 1:16 PM Post #3,401 of 3,717
May 4, 2021 at 1:56 PM Post #3,404 of 3,717
Ofc "uF" my bad :) I have so many capacitors from different producers, with different digits and numbers on it right now.
I'm still learning about capacitors and correct polarisation and capacity.
more resistors at the output.
2x 3kom in your scheme instead 100om?
May 4, 2021 at 2:48 PM Post #3,405 of 3,717
