We are all curious to know how it compares to the other versions
I dont have any other version. So I cant compare. I just bought because it is cheap and it gets AK4499.
So it seems the ak4499 versions 2.5mm is a line out not meant for headphones but for amplifier, and it seems to overheat, . wonder why zishan didn't just use a bigger case,
But I am curious output the output of the 3.5mm I noticed it uses the buf next to the 3.5mm, hopefully has the same output impedance of the ak4490 on ak4495 versions
Hope someone can compare it to the other versions
Maybe it's better to ask the seller before buying, they have both of them on Alliexpress (ak4497/99) maybe they are similarI just canceled the 4499 order. maybe I should go with 4497 instead due to 2.5 mm.
Well I asked about the headphone out, they said on the ak4499 its also 10 ohms, the 2.5mm they said is higher because not for headphonesWe don't know what is the Zishan DSDs ak4499 2.5mm impedance nor if it has gain (sound volume).
I looked at ak4499 datasheet pictures (didn't read any of it) and they use a I-V conversion circuit in the datasheet, followed by a passive LPF.
I can't guess what zishan did from the posted photo, could be the same as the datasheet and that ak4499 datasheet circuit part is very different from ak4497 2.5mm circuit.
I'm not going to buy this, so I contributed the way I could.
Previous post is an educated guess, AK4499 is a current output DAC, the datasheet uses a I-V (current to voltage) conversion circuit (4xdual opamps), followed by a passive LPF (some resistors and smd caps). Seller also says zishan uses a passive LPF (meaning only passive components), no amplification in LFP. In Zishan photos I can see where these components blocks are placed, same as the datasheet circuit, but I can't see the PCB circuit tracks, so I can't say for sure what I can't see. If I had the player I could. I use a multimeter (continuity test) for the hidden tracks.
Anyway I get what you saying, someone interested in buying should ask the seller specific information.
Unfortunately the seller already writes in the advertising that the balanced 2.5 output LPF is passive (LPF has no amplification), it has increased impedance and that the 2.5 output needs an external amp.
Well, I might pass on this one, still don't get why they went this route, I was really looking forward to this, but after owning the first 3 versions of the dsd, I don't think they will be able to top the ak4495 or ak4490.(Emphasis added)
This is an unbelievably poor design decision, for a portable audio device!!!
And, I'm wondering if they can suggest any portable external headphone amps that have a balanced input?
I've got an older iBasso PB2 (now discontinued), but its balanced input is on an Hirose 6-pin connector, so a custom adapter cable is required.
(Emphasis added)
to be honest im satisfied with my modded ak4497 dsd, yes the balanced suck and ive given up on owning balanced cable for my IEM. But the SE Make up for it and i'd pick my dsd any time of the day compared to most mid-high DAPWell I asked about the headphone out, they said on the ak4499 its also 10 ohms, the 2.5mm they said is higher because not for headphones
I can try to ask again but I just told I wouldn't buy yet, they offered a discount
But I think I will wait, but atleast now we know, neither of the new zishans will work well with balanced armature iems, they are pretty much just for dynamic drivers
I think we could all start asking instead of speculating, guessing....
A bit disappointed, was hoping for something like the ak4490 or 4495 versions
