Ivan TT
I also believe that opamp’s ability to drive a capacitive load (and cable+earphones have at least SOME capacitance) is a factor. This issue is often solved by resistors in series with the output, removing them completely may cause opamps to oscillate, this will apply to AK4497 based DSD’s balanced output.
However since AK4497 DSD SE output uses a discrete output stage its ability to handle capacitive loads is unknown, as well as if its ability of handling short-circuit condition (which happens for few seconds when you turn Zishan on by the way), so SOME resistance should be maintained.
