The TWS + Neckband + BT Cable Adapter Thread
Jul 11, 2021 at 11:02 AM Post #288 of 557
So is there an answer on Bluetooth 5.2 on the BGVP. My perfect cable would be flesh behind the neck, USB-C charging (Qi charging would be even better) and BT 5.2 for that increased bandwidth.
Looking to pair with
Jul 18, 2021 at 5:25 AM Post #289 of 557
QCC5xxx with DAC/amp chip, LDAC support, EQ maybe?
Right on - at the moment my utws3 is gathering dust because while SQ might be good compared to other tws is not good enough for critical listening. Make it sound like a portable dac/AMp thats worthy of pairing with decent IEMs and I am there. (and not only that you'll totally dominate the market)
Jul 21, 2021 at 10:13 PM Post #291 of 557
Jul 21, 2021 at 10:53 PM Post #292 of 557
Jul 31, 2021 at 2:37 PM Post #293 of 557
What solution do you have in mind for the ideal UTWS5? :L3000:
probably super late to answer this, but:
- larger room for bigger IEMs. I've seen a couple of pictures of people modding their cases to fit their CIEMs. would be cool to see bigger charging case to fit everything
- modular connectors! adding to the standard MMCX and 0.78 2-pins (both recessed and flat), maybe introduce QDC type connectors as they're becoming more and more popular in newer midrange-budget IEMs
- QCC5125 with great AAC support?
cheers!
Jul 31, 2021 at 3:27 PM Post #294 of 557
cheers!
Actually by the picture found on FCC, UTWS5 will have almost identical outer design as in UTWS3 - so no larger case or modular connector.
Jul 31, 2021 at 10:19 PM Post #298 of 557
Made by Yongse (*a fairly well known headphone cable brand in China). Modular design, QCC3040 + amp chip. ETA in August, no other detail yet
