- Dec 30, 2013
Country music :eek:
The mere mention almost made me leave the thread permanently!
Country music
A broad variety.
If you take a look at any of my reviews I have a select list of songs that I use to evaluate gear.
I don't consider the purple to be "smooth" as described but rather the most balanced sound of all the valves.
Blue sure is easy to listen to!
I find the purple valve to be the best sounding valve by far for me.
Would the t096z be Ideal to use with a headphone tube amp? (Schiit Valhalla2?)
I don't own a tube amp and when I've listened to them in the past it was with near field speakers. I've sure some will argue with me but I've found that IEMs are much less amp dependent than full sized headphones; they don't require the same amounts of power. Currently I'm using an HRT Microstreamer and I'm very pleased with how it and the t096z pair up, there's no shortage of power or volume. The t096z are not difficult to drive; I don't have an impedance number but I doubt it's unusually high. Remember that this IEM can be paired with an iPhone (as indicated by the included microphone), anything above that is gravy.
Thank you,
Well the specs say it's a 150ohm IEM, so isn't that more difficult to drive? It's also 80 or 90 dB of sensitivity? My IEM now is only 12 ohms
It's 16ohms and designed for portable use. At 90dB sensitivity, it's not the most efficient driver but plays plenty loud!
Ok, so it's not 150 ohms?
You got the specs straight from Torque. This isn't a difficult to drive IEM. Most are not. Sometimes, especially with CIEMS containing multiple balanced armatures you have to be concerned with impedance, that's not an issue here.
Even paired with a Clip Zip the t096z plays at a decent volume.
