The Stax SR-L500 and SR-L700 Impressions Thread
- Thread starter crazychile
Hubert481
Yes,
D50, Paltauf and others ...
Forget D50 - it has an annoyingly hum and sounds lifeless.
- Jun 20, 2010
Yes,
There might be something wrong with the one you listened to. Mine has 0 hum with the Omega.
Hubert481
Meanwhile i know 4 owners of the d50 with hum.
And 2 owners without hum . Including you.
- Jun 20, 2010
I'm swapping mine for another due to some cosmetic damage. I hope my new one doesn't buzz.Meanwhile i know 4 owners of the d50 with hum.
Maybe the design is susceptible to ground loops? Have you tried a ground isolator or similar?
Hubert481
No, i sent it back 2 days later
The dealer tried to let it repair by stax germany
But stax germany said, this is normal and the way it is.
Seems to bea chinese construction error
Beside, the next construction error is the cooling system - there are no ventilation holes on the the top of the amp
So the unit gets very hot - this will not encrease life time
- Jun 20, 2010
The top gets to about 112 F on mine.
What input produced the hum? Mine is fine over optical and USB.
Hubert481
No input - always hum - if something is connected or not, it doesńt matter
- Jun 20, 2010
Well, got my replacement SRM-D50. This one doesn't buzz either. Doesn't have any cosmetic flaws, but the input toggle switch is loose. Does anyone know how to tighten it?
Edit: Tightened it. Had to open the case and tighten the set screw on the switch.
florence
- Mar 23, 2014
Hey all,
Anyone who has L700 ever combined srm-310 amp? Really looking forward to hear some opinions in this regard.
I have sr-507 and am driving it with good old (IMHO) srm-310 all sound good. I've got a chance to combine them with srm-006ts, nothing changed, it did sound like a solid amp.
Since L700s have the same Omega membrane, I worry whether it needs high price amp and mine will fail to drive it properly.
alphanumerix1
l700 vs utopia thoughts on how they compare?
Yoram Diamand
- Mar 29, 2017
Hi, the L700 are real lambda stax, easy to drive with a srm-006ts, I use the T1S which is the same idea and I have no problems. Kind regards YoramHey all,
florence
- Mar 23, 2014
Thanks for reply. Just got the L700, srm-310 drives them easily, very powerful Stax amp.Hi, the L700 are real lambda stax, easy to drive with a srm-006ts, I use the T1S which is the same idea and I have no problems. Kind regards Yoram
..i am also very happy with the srm-D50.....no huming noise...no problems since weeks
NOMAX
NOMAX
