Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
Alright, SO, to start out, I previously had/still have a pair of V-Moda M80's. However, I just now finally made the dive into open headphones and ordered a pair of AKG K7XX's from Massdrop. I've been researching a bit into amp/dac combos since I'll need them to drive the K7XX's and get the most out of those badboys. From what I've read it looks like the Magni2/Modi2 combo looks like the best bet for what I'm willing to spend, and are unbeatable at this price-point, but here's my question.
Without digging through hundreds and hundreds of posts, and sorry if this has been answered prior, but can anyone quickly tell me what combo would be most advantageous for me to buy? Is it worth the extra $100 to buy the Uber editions of both the Magni2 + Modi2? Or should I buy just the Uber edition of one, and then the base version of the other? Or just buy the base versions of both?
Any input about this Schiit would be greatly appreciated! Thanks!
I got the Magni 2 Uber since I wanted the preamp outputs to connect active monitors, plus it has slightly higher output power and looks a little better. At the time, I only had enough to get the Modi 2 (non-Uber), but the differences between the DACs are much less significant than the amps. I don't need anything but USB anyway, so it worked out nicely.
It mostly depends on whether you want the extra inputs and outputs. (Unlikely in the context of listening to headphones on a PC audio system.)
Your K7XX won't ship until February 17th, right?
