thanks!
i recently got a multimeter and also this headphone impedance test box (i'll have to figure how it works, i guess it has just some resistors and 3.5mm i/o):
https://world.taobao.com/item/41340690348.htm
i want to measure frequency response mainly, but also impedance, impulse response, and THD.
it's a hobby, so i don't want to spend too much in it now. that's why i haven't bought a DMM yet (i adjust levels by ear, lol). but i 'm taking good notes about it (DMM and E-MU 0404), for a possible future. than you so much for all the info and for confirming that the input of my soundcard is decent enough for FR measures.
You can't adjust levels by ear. How do you know that whatever device that's being tested is outputting say 1 Vrms? You could in theory adjust levels with the ADC of your PC if you have a device with a known max output voltage at 0 dBFS. But my god, it is going to be a complete hassle. With a multimeter you can do it in a couple of seconds.
It seems the impedance test box is actually more than just resistors. By looking at the graphs looks like it emulates the impedance of balance armature IEMs. You will probably find an RLC circuit inside.
By the way here's a bit of useful links:
http://reference-audio-analyzer.pro/en/
https://www.seeko.co.kr/zboard4/zboard.php?id=m_device&page=1&select_arrange=headnum&desc=asc&category=&sn=off&ss=on&sc=off&keyword=&sn1=&divpage=1
http://nwavguy.blogspot.com/
http://www.innerfidelity.com/headphone-amp-measurements
http://archimago.blogspot.com/
This guys tests ADC's
http://www.innerfidelity.com/images/AllAmpsJuly2013.pdf
http://ko.goldenears.net/board/GR_Amp_DAC
http://goldenears.net/board/GR_Mobile
http://monoadc.blog64.fc2.com/blog-entry-99.html
https://www.reddit.com/r/headphones/wiki/tech/output_impedance_database
Edit, just wanted to share this, it is a A58M-E, it has a high output impedance (82 Ohm @ 1 KHz), and measured even higher at low frequencies (output coupling capacitors), so I gave it a try. With 32.5 Ohm load (completly resistive):
In case anyone wonders, the max output voltage at said load was 0.354 Vrms at 1 KHz, the limit was 0 dBFS, not clipping.
