A bit quiet in here, perhaps I can pose a question to the pentode cognoscenti. I recently received the Visseaux 6M6G shown below, but before using I noticed it has a "stray" wire coming out of one of the holes on bottom, as pictured. Is that a concern that it may could cause a short or other tube bad behaviour? Should I clip it the wire at it's origin it doesn't come in contact with the pins?
Don't clip it!!! Most likely that wire is continuous with the coating on the outside of the tube, which is a metal shield, I bet that wire is continuous with pin 1 with the intention of grounding pin 1. Check continuity between the wire and pin 1 with a DMM.
