The Reference 6SN7 Thread
Feb 19, 2023 at 9:47 PM Post #8,462 of 10,650
Was wondering if anyone is familiar with zalytron 6sn7gt I just bought one and it looks very similar to a Sylvania bad boy internally and externally.
Feb 20, 2023 at 3:15 AM Post #8,465 of 10,650
Ok... which one you Frankenphiles outbid me on this group of possible Frankie candidates?
Whoever it was, I thank you. You saved me money for nothing.
Earlier this weekend my prized CBRZ Frankie would no longer heat the heaters. I did what any tube hoarder collector would do. Go shopping for healthy Frankies, Didn't need 7 - probably only a couple in this batch anyhow.
After losing the auction, the only option was Frankie resurrection. And with a little tap-tap tap - and a withering gaze of scrutineering unleashed upon its dark innards - Frankie came back to life! Heaters heating. Signals signaling. The whole tubular operation was back and I frolicked in the sonics.
The moral of this story. Tubes are tough. And so are their hoarders custodians. :beyersmile:
Feb 20, 2023 at 9:14 AM Post #8,467 of 10,650
I have two tubes with dead heaters. They died in my 'care'. I just read about resurrecting a loved tube by heating heater the pins. Should have thought about it before since I have treated noisy tubes this way.
I have “healed” at least a dozen octal tubes by resoldering. Kind of hard to do with a loctal though. Three cheers for the obvious sorcery employed by @LobalWarming .:relaxed:
Feb 20, 2023 at 12:05 PM Post #8,469 of 10,650
CBRZ?
Feb 20, 2023 at 6:44 PM Post #8,471 of 10,650
They are very good and are CBS Hytron.
Feb 20, 2023 at 6:49 PM Post #8,472 of 10,650
Feb 20, 2023 at 9:39 PM Post #8,473 of 10,650
How many of these had dead heaters? :thinking:
None that I know of. Two had dead triodes, but I don't remember looking to see if the filament was lit (they had zero GM in the tester). Most were just noisy or crackly.
Feb 20, 2023 at 9:41 PM Post #8,474 of 10,650
Feb 22, 2023 at 1:02 PM Post #8,475 of 10,650
I purchased my first vacuum tube headphone amplifier - Cayin HA300MK2 - about 4 months ago. I have replaced the stock Tungsol 6sn7GTB tubes with RCA smoked glass 6sn7GT tubes manufactured in the 1940s. I noted that a background noise developed in the one channel. I presumed that I had a noisy 6sn7 driver tube, but when I switched the driver tubes from left-to-right the noise disappeared. I then read that the most common cause of a noise problem was a poor electrical connection between the tube's pins and the metal contacts inbuilt into the tube socket, and the recommendation was to clean all those metal parts.
As a neophyte vacuum tube amplifier owner, how can I learn how to clean the 6sn7GT driver tube's pins and the metal contacts that are inbuilt into the tube socket?
Jeff.
