Fotons are the reason I started replacing the solder in 6sn7 tube pins. People claimed they needed a super long burn in and I thought that a little crazy so I conducted some experiments with the pins, new solder, and a long test cycle. To the best of my recollection
@bcowen who is the resident Foton expert went back and checked some tubes that he had applied the long burn in time to and found they were still acting like they did prior to said burn in. Bill can answer this better but the best Fotons are from the fifties and have ribbed plates. 1952-1957 I think but Bill can answer that better than me.
As best I recall the socket extension is needed on the Vali, the socket on the circuit board sits fairly low and will not allow an adapter otherwise. This is back when I did a lot of experiments with 6J5 single triode tubes, the device in the back had a 9 pin socket closer to the top of the amp so a 9 pin extension was not needed there.
