mordy
- Aug 8, 2010
Well, I just thought that you might enjoy the ECC32 sound for a fraction of the cost of that $400 tube. The first time I used an ECC31 tube I got a real scare - the whole tube flashed an orange flash and I thought: OH NO! The tube I have is a very early one and I don't know if later ones have this feature: a quick heat feature that flashes the heater on start-up for quick warm-up. But it is perfectly normal for tubes with this feature and the quick heat feature was used in other tube types as well.Hoo boy. Guess I'm adding some ecc31 tubes to my order. Oh, and another adapter. It's just money, right? That'll be the, oh I don't know, the 6789th adapter I'll need.
Any 6n7 I should look into as long as I'm going to be @Deyan 's retirement plan?
The 6N7 has the same pinout and you can get the metal ones very inexpensive - as always the K-R have good bass. Some people like the Visseaux 6N7G and GT as well, but pricier by now.
But let's face it - you probably have enough tubes that you could spend a lot of time finding very good synergistic combinations with the stuff you have, instead of buying and exploring new tubes.
