The Reference 6SN7 Thread
May 26, 2024 at 5:22 AM Post #10,051 of 10,650
Sonically it's sounds warmer than a Raytheon vt231.
I think Mullard had a factory in Australia. There is a Mullard labelled 6sn7gta version that was build in Australia. Sadly I can't find a picture of those tubes.
There was a Philips plant in Adelaide, Australia. If I remember correctly there was a time when tube internals were assembled in England and shipped to Australia and then the tubes were completed there.
May 26, 2024 at 5:58 AM Post #10,052 of 10,650
Noob question for you guys. Seems like different branding has a different "house sound" for the same tube, eg, RCA, Kenrad etc. If using a 231 as an example, how do they each produce their own house sound? Is it all just slight variation in the make up of the tube?
I've got a pair of Kenrad vt231's here, not a bad sound by any means but the mids are too lean paired with Taks. If I changed them to an RCA vt231, would that be essentially the same sound technically but with a tonal shift?
May 26, 2024 at 6:20 AM Post #10,053 of 10,650
By comparison, RCA 40s VT-231 will sound thicker than KenRad VT-231, can be perceived as more laid-back. Though, some people might find it too dark for their taste but they are amazing for genres like Jazz and Blues. You really have to try them yourself to find out, just make sure you get those early 40s smoked glass with the old "meatball" logo. If you havent tried these yet, most British tubes like Mullard, MWT / GEC, STC / Brimar, etc (except Tungsram), have a richer and thicker mid. Have fun with your exploration.
May 26, 2024 at 7:11 AM Post #10,054 of 10,650
And how do they make their own house sound, is it all down to slight variation in model design / tuning?
May 26, 2024 at 7:26 AM Post #10,055 of 10,650
I believe it is due to physical structure design (eg. shape of plates, grid wiring, etc) as well as material content since they all followed the same electrical specs of the prototype.
May 26, 2024 at 11:01 AM Post #10,056 of 10,650
Did you grab a pair of a 40s AWV vt-231 smooth plates or a nice pair 50s pair with staggered plates ?
Westinghouse and Raytheon GTB would be only a side grade.
Sylvania GTB is a great performing tube for a fair price.
Depends to your budget and your sonical preferences. For sure RCA vt-231 will be a fine upgrade.
RCA never made a black glass 6sn7.
I don't want to go sideways so I might be spending big bucks. I've been looking at Vintage Tube Services out of Michigan but haven't called until I learn more of what I want.
May 26, 2024 at 11:06 AM Post #10,057 of 10,650
This thing is killer
Jun 3, 2024 at 12:01 AM Post #10,058 of 10,650
Hey folks-
I was reading the specs on this tube earlier (6SL7 GT) but haven’t found much in the way of experience with it- wondering if anyone here has used this and if they found it to be a good thing or a bad. Any thoughts would be appreciated!
6SL7GT
Jun 3, 2024 at 12:06 AM Post #10,059 of 10,650
Hey folks-
6SL7GT
• With 70x gain, probably not useable in lieu of 6SN7(GT).
• 6SL7 is the preferred input tube for the ZMF Aegis headphone amplifier -- designed by @L0rdGwyn.
Jun 3, 2024 at 12:22 AM Post #10,060 of 10,650
Hey folks-
6SL7GT
Yeah 6SL7 is very different from a 6SN7, not a direct replacement. When used well, 6SL7 sounds excellent! But has to be used in the right circuit, not in one made for 6SN7.
Jun 3, 2024 at 12:23 AM Post #10,061 of 10,650
Was thinking of picking up a cheap quad and throwing them in the Lampizator. I’ve tried high gain triodes before and it wasn’t horrible but also wasn’t something that became an immediate winner either- just different.
Jun 4, 2024 at 8:08 AM Post #10,062 of 10,650
Jun 4, 2024 at 9:23 AM Post #10,063 of 10,650
Adapter noob question...
I bought these:
VR135 DET20 CV6 Mullard Valves Tubes Close Matched Quad NOS (Set 6)
to use with two of these:
1pc Dual 6C8P 2C22 7193 CV6 CV3601 TO 6SN7GT B65 CV1988 tube converter adapter
on my Feliks Envy
Attached the tubes the only way they can to the adapter, and attached the adapter the only it fits on the amp. But I can't get any sound.
Is the adapter not compatible with the tube quad I bought?
PXL_20240604_114900008.jpgPXL_20240604_114828585.jpgPXL_20240604_114751759.jpgPXL_20240604_114745987.jpgPXL_20240604_114732201.jpg
Just to make sure- have you validated the placement of each cap wire? I’ve been told that the placement is “reversed” on some types. See the attached for 7192/2C22. I believe the cap placement on your tubes would be opposite of this (but please check data sheets to be sure!).
Jun 4, 2024 at 9:37 AM Post #10,064 of 10,650
Thank you, think I get it now!
Jun 4, 2024 at 10:10 AM Post #10,065 of 10,650
I have heard nothing but great things about these tubes but I just don’t trust myself with the adapters lol. I actually own a handful. Bought them a long time ago cause they were incredibly cheap. Not anymore lol.
