leftside
To sound their best, they need to be in a circuit designed for them. That's been my experience anyway.C3G’s showed up the other day (not quite sure they are my cup of tea though)
Have you tried Mullard ECC35? They are an 6SL7 equivalent.Thanks, should have spoken to you first. Lesson learned
Also I just picked up a Cen.Grand Silver Fox, which will pair nicely with my Caldera (so I can stop searching for drivers other than 6SL7 that work well with them in the Agartha)
Might be a matched pair of C3G’s & adapter in the classifieds soon
That would be a tough decision for me. Paired with 300B I'd go with C3G, otherwise I'd go with 6J5. In one of my amps I had @A2029 build me separate 6J5, 6SN7 and C3g sockets. There is a definite difference in sound between 6J5 and C3G. More than the difference between different 6J5's.I never did like them in my Glenn. I had @L0rdGwyn rewire and swap out the C3G sockets on my GOTL and replace them with 6J5 sockets.
It’s nice to have the option. I can hear strengths in both C3g and 6J5. In my 1101 amp I hear the C3g as having a sense of pristine clarity in a vast open space. The 6J5 tend to have more harmonic richness and density. Though power tubes and other factors can swing things one way or another.That would be a tough decision for me. Paired with 300B I'd go with C3G, otherwise I'd go with 6J5. In one of my amps I had @A2029 build me separate 6J5, 6SN7 and C3g sockets. There is a definite difference in sound between 6J5 and C3G. More than the difference between different 6J5's.
Yes, they sound great with my Caldera on the 8 Ohm tap, but the ECC35 is too noisy for the 300 Ohm tapHave you tried Mullard ECC35? They are an 6SL7 equivalent.
Try them with WE300B.C3G’s showed up the other day (not quite sure they are my cup of tea though)
No longer have WE300B, but from the short time I had with them I can see how that would be a good pairingTry them with WE300B.
Though the 5a/152m are magical.
Most unfortunate. One needs both WE and an Elrog of choice. But that is a big chunk of change, for sure.No longer have WE300B, but from the short time I had with them I can see how that would be a good pairing
That was my plan, until one of the WE turned noisy. I’ll probably buy another pair but not anytime soonMost unfortunate. One needs both WE and an Elrog of choice. But that is a big chunk of change, for sure.
Even with Elrog TM, I still enjoy having the WE.
Apparently running the c3g as a pentode is the way to go for driving the 300b. Needless to say that would be a very different circuit!That would be a tough decision for me. Paired with 300B I'd go with C3G, otherwise I'd go with 6J5. In one of my amps I had @A2029 build me separate 6J5, 6SN7 and C3g sockets. There is a definite difference in sound between 6J5 and C3G. More than the difference between different 6J5's.
Most of us are running C3g as triode strapped pentodes in quads on amps like Envy and HA300-2 that take pairs of 6SN7, using both triodes per 6SN7 tube. I wonder what the difference would be running as a pentode with purpose designed circuit.Apparently running the c3g as a pentode is the way to go for driving the 300b. Needless to say that would be a very different circuit!
I know just enough to be dangerous when it comes to circuit design. With that caveat out of the way my understanding is that some pentodes like c3g or d3a are better able to handle the Miller capacitance of the 300b than the typical triode drivers. It’s really common to see mosfet followers or paralleled triodes as drivers of 300b outputs but apparently those particular pentodes can do it directly.Most of us are running C3g as triode strapped pentodes in quads on amps like Envy and HA300-2 that take pairs of 6SN7, using both triodes per 6SN7 tube. I wonder what the difference would be running as a pentode with purpose designed circuit.
