Underdog311
- Jan 14, 2005
The HD5 looks like total garbage anyway.
Originally Posted by bangraman At flat EQ with the same test load, all the other players that I've measured either measure flat, or players which are affected by a bass falloff due to the same problem as the iPod eventually measure flat but not beyond. I'll have new results in a week or so. |
Originally Posted by breez WTH? Did they forget to look at the scale! It's not going to be audible. |
When the two don't agree, psychoacoustics is right, because it's based on REAL listening test on REAL humans, using REAL listening test methodology. |
Originally Posted by bangraman It's surprisingly noticeble for such a small deviation and definitely makes the HD5 sound 'nicer' |
Originally Posted by KeanosMagicHat Probably missing the point of this thread hugely but surely this should be the conclusion? If it sounds "nice" why does the fact that there may have been some technical jiggery pokery behind this demean the player in some people's view? Surely if the sound quality is good Sony's sound engineers should be applauded for whatever they have done behind the scenes to achieve this? Or is that what's happening here? Perhaps it's a language barrier? |
Originally Posted by sonance If you look at the iPod's headphone output frequency response into a typical resistive load representing a connected pair of headphones, the bass response from 0-100hz makes the < 0.5db variance from the Sony look exemplary. The 0-100hz range requires the most power from the headphone amp and it reacts differently depending on the connected load. I don't know if your rightmark analysis takes that into account. Would the response curve look the same into a 120ohm load? How about an ultra low load such as typical IEMs or ultra high load such as some of the Beyers? The bass response would likely be affected the most by changing loads. The effect of your headphones would be *far* greater than that < 0.5db variance. |
Originally Posted by SDA Who's to say that this thing is the cause of whatever audible difference there is? bangraman said it himself, it could well be something else. It's not as if everything else is identical with these players, not by a long shot. |
