Of course people are buying the gsx for the surround and not for its musical qualities. Equalizer apo looks nice on paper but it's a lagfest when it comes to latency.
HeSuVi is latency free (0ms)
What are the correct settings for using Dolby Headphone on a headphone setup on MPC HC/BE + LAV filters? Sound card is Xonar DGX, headphones (Sennheiser 380 Pro) plugged into headphone jack. The source will be 5.1, 7.1.
In windows (10 x64) I set up the speakers as 5.1. I select 6 channels in the sound card, and headphone for analog out.
In the LAV Audio Decoder Properties - Status I can see the bars for 6/8 channels in the Input and Output going up and down (during playback).
The mixers in MPC HC (Internal Filters > Audio Renderer) and LAV are deactivated.
Ignore system channel mixer ticked on. Not using WASAPI. Using Reclock.
Are the other options for virtualization (Sonic, HeSuVi) better than Dolby Headphone?
@mindbomb, the analog is still set at headphone and not speakers?
I've used CMSS 3D for a long time but I found HeSuVi sounds better with "OpenAL soft HRTF" natural and pinpoints without compromising the audio quality
I see that you have tested quite a few HeSuVi modes.
Have you found out the one that in your opinion is the best in front-back localization? The OpenAL is lacking in this regard for me personally (on my setup with TR-X00 headphones).
Thanks!
Anything better in terms of sound devices now?
