rudyae86
- Oct 10, 2013
Thanks bud.
I actually found it just a few minutes ago lol.
He showed a review from someone else and says that its really good.
Still skeptical but makes me want to try it out
Many of you have much more sophisticated sound setups than me. But, I'm happy with my new PC that I just finished:
Mini-ITX form factor case - The Ncase M1 (one of the very smallest out there right now... was a tough build... tight quarters)
Asus Z170i Pro Gaming motherboard
i7-6700k
Noctua C14 HSF CPU cooler
nVidia 1080-FE
Corsair DDR4-3200 (16GB)
Corsair SF600 power supply
With no room for a separate sound card with the Mini-ITX size, I went with an inexpensive DAC, the Udac3. My Sennheiser PC360 headset I use when the wife is home. When she is not home I use the powered M-Audio AV40's (2.0, I may get a sub-woofer). The RCA's and the headphones plug into the DAC. We play a lot of Battlefield 4 and 1 and have been happy with the sound.
i7-6700k
nVidia 1080-FE
Honestly, I don't know... why?
Can you test if the Virtual Surround is also being sent to the line output?
Surround only works from the headphone jack.
Well that is a bit of a bummer. The soundblaster Z's have a speaker variant that isn't as good as headphones but produces a better effect than just stereo.
The big issue on not having the surround options on the line out is the ability to use the unit as a DAC attached to a separate amp. I'm sure that people with higher end cans would want to use their existing amp rather than the integrated amp in a gaming device.
