BiggerHead
- Mar 9, 2013
I'm not the most experienced headfier here but I've got a long history on more technical matters than this and I've paid quite a bit of attention to this so I'm going to butt in here and give my take on some of this, similar to another thread about measurements elsewhere yesterday.
If you stand at Niagra falls, and let's just pretend that niagra falls is white noise, lets' imagine that a perfect microphone placed at some spot not inside a head would measure a flat spectrum. Ok this is a real thing, now you go and stand where the mic was and you hear it. However you hear it, that's how it really should sound.* (every time I make this star it will mean give or take the bass boost room correction, see my comment below) It doesn't sound like a flat spectrum. It sounds like the inverse of an equal loudness curve, which incorporates some product of curves, basically HTRC*: "transfer function" from diffuse field(or free or whatever) to ear canal and BRC: Brain Response Curve (I just made that up).
Now if you have a perfect speaker system (easier than headphones so lets start there), and play back your Niagra recording it should not sound flat to you because the real Niagra didn't sound flat to you. So if you do a frequency sweep with your speakers you should not eq the result to a flat sounding curve. With reference speakers of course (give or take room effects) you won't have to eq it at all, but if you eq it, it should* be eq'd so a mic in the listening position would pick up a flat spectrum. Now if you play back niagra, the mic will pick up a flat spectrum just like there was in front of Niagra. If you put your head there, you'll have the same input to your head as you had at Niagra, a flat spectrum, and you'll hear the same thing, not flat. If you played an equal loudness curve, that by definition would sound flat*. I think maybe this is what Joe Bloggs does, but not what he said to do. (I'm intentionally oversimplifying diffuse field, free field and directional stuff, fine, but if you would have been facing Niagra, maybe that all works out reasonably ok).
Ok so you put on a set of headphones and you want to hear that same thing. Tyll measures what sound gets inside his dummy ear. Someone said he has to correct that for human hearing and someone else objected. Well he has to correct it for how sound gets in your ear, if he wants flat on his graph to mean Niagra sounds real. Of course that's not correcting the headphone response for human hearing for a couple of reasons. 1) It's not measuring "the headphone response". That's actually impossible. There's no such thing. There is only the response produced by the headphones, measured somewhere, in some setting, but anyway, this is far from "the headphone response". It's measuring "the headphone response" modified already by part of the human hearing system, the ear canal. 2) It's only modified by part of the human hearing system, not the BRC (neural bits). So it's correcting the headphone response modified by part of the human hearing system... for that part of the human hearing system that already modified the actual measurement. That really isn't "correcting the headphone response for human hearing". This really is an important point I think**.
So why not just measure the headphone response with a mic outside the ear? Because that won't/shouldn't be the same as a diffuse field niagra recording either and while it doesn't depend as strongly on ear shapes, the relationship between that and the sound at your eardrum probably does depend significantly on headphone shapes. Now you'd need an HTRF for every headphone. This is a problem speakers didn't have and is the reason speakers can be measured outside of the dummy head. I think this is an important detail often missed.
So.. he measures inside the ear and wants to have a flat input to sound to the mic like the HTRC. If that happens and he subtracts (divides... but subtract if we're working in db ie log scale) the HTRC he should see a straight line. Of course that doesn't happen because headphones aren't perfect. He still subtracts though and we see how close it gets.
So back to eq'ing... I certainly also didn't understand (and still don't) in the original post how the HTRC was meant to be used, step by step, in the process, but I just can't see how it could be if you're using hearing as the judge. The HTRC is the sound in your inner ear from a flat spectrum at Niagra*. It's not what you hear. What you hear at Niagra is the inverse equal loudness curve, probably because of nerve and brain issues beyond that. So how can you use a human hearing based eq system and also use HTRC as any useful reference? This doesn't make sense to me. What would make sense to me is an equal loudness curve played on speakers should sound equally loud in all frequencies (that's what it means). And that same curve played in headphones should sound the same, ie equally loud in all frequencies, in headphones. We should NOT be correcting measured heaphone spectra with equal loudness curves, that's a different issue and common false claim, but we aren't talking about measurements here. So this actually seems very simple to me. Just play equal loudness curves and make them sound like equal loudness regardless of what equipment they are played on. After all, speakers should sound the same as headphones right? Which equal loudness curve should you play? That's the hard part. It should be the one corresponding to the volume you are hearing when you do the eq. Your head will modify appropriately for other volumes. So you need a way to sort that out.
* About that room bass. I think it's neat that the industry has finally realized that people listen to music in their living room and the brain expects that, but the brain hears many directional cues of where the walls are with speakers. With headphones that doesn't happen and I'm somewhere else anyway. I don't want it then, and I think it's wrong and is just justification to play into people's apparent enjoyment of bass (which is fine, in the recording).
** I hope/think Tyll is still using his own measurements with his own dummy for his own version of an HTRC. This means that he's correcting the mic in his dummy head with the HTRC for his dummy head. There actually shouldn't be much caveat left about head to head variation. He makes it sound right on his dummy head. Of course it will sound different in your ear canal, but everything sounds different in your ear canal. It's supposed to. Niagra does too. There's no problem here unless the resonances set up between your ear canal and a particular headphone create a strong effect that doesn't exist normally without headphones and also that doesn't exist in the other head.
