LarsMan
Please forgive me my semantic errors.There is a big difference between lacking and comparatively lacking![]()
My Silver Dragon cables for Susvara just shipped and I hope it would bring improvement like you said.For me Susvara was definitely something that improved massively overtime. I think it has something to do with break in of the drivers and changing the cable. I was already thinking about selling it, it was lifeless, flat, muddy and boring. I've noticed that it wasn't responsing to EQ when adding more than 6db bass shelf, and that got me thinking. After a few days running it with +12dbbass shelf, and changing the cable in the meantime, it became a totally different set. It's still flat and neutral, but the drivers definitely gave in a bit, macro dynamics and bass came through with force, to a point when I can make it practically as impactful as the TC, which is the bass impact king.
Another breakin episde is with my Cayin HA6a which was noisy at first but over time it became less and less nosisy. It still has a noise floor on sensitive headphones but it's barely noticable now.
But yeah, for many pieces breakin doesn't really change that much.
No, I currently only have Bifrost 2 / Jotenheim 2 stack. I will demo and hopefully purchase OOR stack next week only. I have no clue about whether burn-in for Susvara is real or not, and if so, how many hours it would take and how much improvement there really is. The sound currently is brittle, dry, and lacking body, and yes bass is anemic. I am attributing the subpar sound to my amp not nearly driving the Susvara to their ideal levels. I do not have OOR yet but I do see a +db switch on the unit.It doesn't take 6 days to burn in HFM, at least not from lame/weak to awesome/weight/full. I have no idea what OOR stack is but your dac and amp are anemic. Does OOR provide at least 2-3w on SE output with low gain setting (3 and below)?
Oor has 8w per channel into 60 ohms, which is more than many high class speaker amps (60w into 8 ohms more less). Should be enoughIt doesn't take 6 days to burn in HFM, at least not from lame/weak to awesome/weight/full. I have no idea what OOR stack is but your dac and amp are anemic. Does OOR provide at least 2-3w on SE output with low gain setting (3 and below)?
So that's 2W into 60 ohm in SE mode - enough but barely to be honest. Does the power double down with every halfing impedance in SE mode? Balance just adds 6db voltage gain to the output, so I generally calculate suitability based on SE mode.Oor has 8w per channel into 60 ohms, which is more than many high class speaker amps (60w into 8 ohms more less). Should be enough![]()
Burn in is real and the first few days can have audible changes, but you have been playing it for a week now. Whatever improvements after that will be minor TBH.No, I currently only have Bifrost 2 / Jotenheim 2 stack. I will demo and hopefully purchase OOR stack next week only. I have no clue about whether burn-in for Susvara is real or not, and if so, how many hours it would take and how much improvement there really is. The sound currently is brittlem, dry, and lacking body, and yes bass is anemic. I am attributing the subpar sound to my amp not nearly driving the Susvara to their ideal levels. I do not have OOR yet but I do see a +db switch on the unit.
So you were impressed by the Susvara but ultimately sold it still, was it because you got the Shangri-La Sr in place of it?I'd agree with a few others. I'm not much of a believer in burn-in.. I have always personally believed that it's almost always just a mental adjustment which is attributed to "burn in". It also took me a weeks to get used to the Susvara and to understand it's strong points. I thought it may have been burn in, but eventually realized that it just has a really subtle presentation. Nothing jumps out at you immediately.. but over time things do.
They could also just not be for you lol, but just sharing if helpful.
Yes, I have spent almost a week with it, and everything is just too laid-back, vocals are too far away to feel emotional, there are many details but they're too subtle to appreciate easily. Body is also lean to be really engaging.
I had very similar experiences as you are having. I bought the Susvara, sold it off, then a few months later bought another one when I was forced to upgrade the chain.So you were impressed by the Susvara but ultimately sold it still, was it because you got the Shangri-La Sr in place of it?
I dunno. I have had headphones (LSA HP-1 come to mind) that sounded awful out of the box, then I let them run for several days without listening to them, and then give 'em another listen and they sound like different headphones they're so much better, so 'mental adjustment' was not involved. Appreciate your sharing your experience with Susvara, though!I'd agree with a few others. I'm not much of a believer in burn-in.. I have always personally believed that it's almost always just a mental adjustment which is attributed to "burn in". It also took me a weeks to get used to the Susvara and to understand it's strong points. I thought it may have been burn in, but eventually realized that it just has a really subtle presentation. Nothing jumps out at you immediately.. but over time things do.
I dunno. I have had headphones (LSA HP-1 come to mind) that sounded awful out of the box, then I let them run for several days without listening to them, and then give 'em another listen and they sound like different headphones they're so much better, so 'mental adjustment' was not involved. Appreciate your sharing your experience with Susvara, though!![]()
I've recently upgraded the connectors on my Toxic SW22 (silver/gold) cable for my HEKse. With the conclusion that the connectors are also very important and well worth getting the best available for that cable. I fitted the connectors myself and, despite my dodgy amateurish soldering skills (using Oyaide silver solder), the SQ differences were obvious from the first few seconds of listening.What material of terminal did you choose and did it make a difference?
