The case is actually good looking. However, the design, features, are making the N8ii to be warmed up by much, and staying inside the case, the evidences is that the charging will be limited as a protection mechanism. Per
@Andykong explanation, 45-50c is the trigger of the protection mechanism...given that the body is about 70% effective of dissipation generated heat. Then it is explainable that by the time it reaches 37-41C, or about body temperature, the player stopped charging. Now, when you have it slipped inside the case, the body will not dissipate heat as well, the internal will easily reach 47-50C, the charging mechanism will be enabled more than often to protect the player.
My point is that, I donāt mind about the case, and I like the design. Give the body weight and the way you have to pointed it downward before you slip it into the pocket of bag, just because the phone plug is on the bottom, the player may easily slide out. What I do worry about is the warmth/heat generated by the N8ii. Hence, I just want to use it without the case.
Now, if only that Cayin provided more than 1 screen protector glass inside the box, so people have a choice to apply on both the front/back, and use it without the case. If you must use it portably and on the go, choose the SS/AB
