kcazbarach
- Jul 5, 2011
Have an older computer running on xp, installed ASIO and ASIO4all v2, I 'think' it's bypassing the extra processing. It does show asio4all under device and the green box on the taskbar. How can I check to be certain?
Have a newer computer running windows8. Have installed WASAPI, it shows in the installed components window, even checked the components folder, it's there but under playback>outputs>device>it's not there. Computer volume and sounds play through the external dac which also indicates no wasapi? Where am I going wrong???
This would be feeding a modi and/or by later next week an aune x1 through usb.
for ur older computer and asio, the greenbox shows up on the task bar, and the only way it isn't functioning is if you click on that greenbox and it shows and X or something to indicate it's not working.
I guess you can be certain by starting foobar with asio and trying to play something on youtube or any other audio. (it shouldn't work in conjunction).
Your asio set up seems fine from how you explain it.
I can't help you on your 2nd problem though, that's stumping me as well.
