big45-70
- Nov 3, 2013
How difficult is it to replace a battery on a X1 should the need arise?
X1 Come with 2 xtra protectors kit in box. 2 layers only. (1) (2) 2 parts. Weird & confusing!I think there are 3 layers. Remove 1, and u reveal the sticky part. Remove 2, and probably u get that nice finish.
Thx for the infos. I was only confused by the (2) tag. The one pre installed is so perfectly installed that I was thinking that it was nothin there on the screen. The protector is so thin! Unfortunately, it leave easily marks on screen!...Skullbox, the little tab is connected to a disposable piece of clear plastic. Pull back on the tab to peel the cover off of the screen protector. It should not remove the protector from your screen.
Each screen protector has two covers on it to prevent you from getting finger oils on the protector itself. You peel one side off and press that side onto the screen through the other removable cover before taking it off, as well.
Your screen protector is already applied properly, so just remove the second cover and you're good to go.
I haven't seen the inside of the X1 so not sure about the battery. If it plugs in like the iPod Video it shouldn't be too hard but if it needs soldered like the nano it will be more of a problem. Hope not but with care taken the battery could hopefully last a good five years.
Is anybody using ATH-IM70 with FiiO X1? What is your settings for equalizer?
After Xiaomi Piston 2.1 Gold i can't say IM70 sounds much better. It's just different.
I use http://en.goldenears.net/31885 review and my EQ settings for IM70 is:
62hz: -6db
160: -6
400: -4
1000: 0
3000: +4
8000: -5
16000: +6
The X1 is becoming hard to find on Amazon. Two weeks ago when I first considered getting it, there were about a dozen vendors each selling the silver and gold ones. Half were fulfilled by Amazon and the other half were ordered through Amazon. Most had a price of $100. When I decided to order a couple of days later, the vendor that I had in my cart had raised the price to $120, so I ordered from another highly rated vendor, fulfilled by Amazon. The vendors started to run out of stock and disappear from the list. Now there is only 1 vendor, with 3 left in stock for $120, for the silver one and 3 vendors for the gold one at $110 to $120.
It's possible that they just still haven't received new shipments of the X1 after the Chinese New Year time off.
I noticed a number of FiiO items went out of stock. I came here to see if maybe new models were being released.
Read above
Pretty sure Miccastore.com (Authorized US dealer/distributor) usually has most of the popular FiiO products in stock. Right now X1 is listed as "In Stock" and "Ships 1-2 days" in both Gold and Silver for $99.99.
