Paul Davidson
- Jan 30, 2014
Love the dark firmware, much better than the bright pre-installed ones.
Limit of 128gb based on microsd.
The ipod video is fairly easy to modify for more storage and plays video with limitations. And can run rock box. There are mods to one terabyte I think. Mine has 256gb. The ipod mini can be modded also and sounds surprisingly good
The X1 has a beefy amp that handles many headphones better than the ipod. Also plays high res files if you so desire.
I have both. And also the x3. For sound my rank ordering is x3 first. Closely followed by X1. But the iPods are not slouches.
Has anyone figured out how to decrease the lag between changing a song and the artwork appearing on the playing screen? It takes about 4 seconds on the X1 and it's almost instant on my rockboxed ClipZip so I assume it has something to do with the X1.
Take any embedded art work out of your files, and just use a single folder.jpg for each album. It speeds up the display quite a bit.
I've never used MusicBee, it looks good. I use MediaMonkey and they seem similar. There might be an option for you in the synchronize settings. In MM that setting is inside the device sync settings->options->tagging.
I cant include images yet, but you can see it here
