Thanks @clee290 for his white on black theme! I decided to use his tips on how to edit .bat files to use the x5 packer to make my own take on his awesome theme. First try any suggestions besides making the logo not conflict with the categories?
1, It is renamed as X3 II, in fact, we will change the model no but the X3 keep the same. something like Audi keep A3,A6,A7,A8 .
2, the new X3 = X1 + USB DAC + bigger power output + Native DSD support + better DAC (CS4398), + Better Amp + coaxial output + 100 US$. btw, the new X3 is a little thicker than X1 and become full metal case.
or new X3 = Old X3 + Native DSD supports+ better DAC ( CS4398) + New UI and ID.
The mass production will be done in April and them launch global market.
What are the chances of creating a FLAC and MP3 player, with micro SD support (up to 128GB) but with the ability to use 2 AAA or AA batteries? Or to use a consumer replaceable rechargeable battery that lasts for a week with 8hrs a day usage?
Or is that too much to ask for?
The X1 is near perfect, but the battery life is just that bit lower than I would like, and not keen that it can't be replaced by the user (easily) if it dies. BTW can the device still be mains powered when the battery dies?
Today I got my Fiio X1. I bought a 64gb class 10 Sandisk SD card.
Now the player has problems with the card. The player takes 3 hours to format it but after that it does not recognize the memory card.
What can I do to make the player work properly? Is it broken?
Where did you get the card from? Have you tested/used the card with the computer or in another device? That's an insane amount of time to format the card :eek:
That sounds great, and if it releases earlier than the x7, I'm getting it to kill the time before the x7 is here. But I have one question:
Is the jitter significantly reduced with this new x3 and x7? And with that I mean, on x1's level? Because I have the e18, x1 and loaned the x5, and the e18 and x5 both cause listening fatigue, and the x1 is totally free from it. (I obviously don't know if it's jitter I'm hearing, but it's a problem with longer listening, and it sounds like the sound gets too hard on my ears. This has nothing to do with highs mids or lows).
