ccfixx
- Aug 21, 2014
Just got my x1. is it possible to shuffle my whole library or just one album at a time? anyone?
One album at a time, as far as I know.
Looking for help / suggestions with the X1 and my car's stock system...
It wasn't until yesterday that I finally found an auxiliary cable lying around to try out the X1 in my car, which is a 2012 Kia Soul+. So, I plug the cable into the X1 and the auxiliary port in my car's stock unit, set the X1 to Line Out, hit play, and... only parts of the songs were coming through the speakers in my car. It's almost as if everything had been panned to one side or the other. I was hearing guitar parts and vocal parts hidden in the mix that I had never heard before, but I was on able to faintly hear the main vocals and main guitar parts of the songs. I shut off the X1 and switched it over to Headphone Out to see if it would make a difference, but I had the same results. All of the files I was trying to play are CD-ripped FLAC files via dBpoweramp. I don't have an amp to try out the Line Out, but if I listen to the music directly from the X1 via the HO, then all is good and well. I didn't try any MP3 files, yet, but I can do that today and see how it goes. It may just be some kind of incompatibility with my car's system. If anyone has any suggestions I would greatly appreciate it.
@iancraig10... Okay, I ensured that both my connection into the X1 and into my car's radio were solid and that nothing was loose, but I'm still getting the same results. I still haven't tried any MP3 files to see if that makes a difference, so that will be my next test.
Check to see if the cable you're using is a mono cable.
If that's not it, the cable is probably defective.
Why did the DAC change? On the website it now says PCM5142. Isn't the WM8740 a much better DAC? What caused this change?
Anyone on x1 pairing with havi b3 pro1?
My brother ordered it from mp4 nation and if it can power the havi ,i may not buy an amp seperately.
So anyone?
