This sounds very similar to Rob’s concern re fibre conversions.Fiber has negative aspects as well. It is not a spread spectrum modulation like Wi-Fi or 3G and above, but a pulse modulation,. A noise coming out of power supply have strong peaks at certain frequencies, it is more disturbing for electronics than spread spectrum from WiFi.
Keeping your network chain as simple as possible is definitely the right direction to be heading in and avoiding fibre and other conversions is very good idea as these active processes generate and emit high-frequency interference picked up from their power supplies and internal powered processes.
Assuming there is HF interference generated by FMCs via their PS and maybe some localised radiated RFI, then the question would be how to best mitigate this to prevent it negatively affecting other components whilst still getting the benefit of their 100% galvanic isolation. Here’s a few ideas, incl some SA junky mentioned for wifi extenders that are relevant here too:
PS noise mitigants
- Linear PS (should reduce, if not fully mitigate, spikes and RF passing back to the mains circuit)
- Power conditioning on AC plug feeding FMC, preferably with a separate and high quality filtering circuit for each AC socket, prevent noise transferring between components eg. PSM156
Conservatively assuming there is some if comparatively low power vs a wifi router:
- Additional RF shielding of the FMC enclosure eg. Copper foil tape
- Chassis and/or signal grounding of the FMC incl any additional shielding
- Locating the receiving FMC further away from streamer… inverse square law means double the distance from say 1m to 2m as SAjunky suggests for a wifi extender, RFI intensity will be one over the square of the distance multiplier I.e. 1/2^2 = 1/4 (downside of this is a longer length of exposed ethernet cable… which could be shielded)
- Linear PS so no SMPS noise at least
- Chassis and/or signal grounding of FMC
- ethernet filter after the FMC (may include further galvanic isolation or noise cancellation depending on the design)
