bpcans
@Jake2, where did you put the iFi Lan Silencer in your listening chain? https://ifi-audio.com/products/lan-isilencer/. I don’t think that I need one, but do you think it’s worth a try?
I'd frame the question another way - how do you know the ethernet signal/chain has been cleaned up (incl reclocking) to the extent that no further audible differences are possible without spending unreasonable money?I’ve watched several YouTube tutorials where folks have 3 to 4 network switches in cascade with basic ethernet cables between their routers and their music servers. When do you know that the internet signal has been reclocked enough to make a substantive difference? Is it all about what how resolving one’s system is?
Thanks to @sajunky observation Im gonna link this here: https://audiophilestyle.com/applica...d=106927&key=0dd72ee9e223f9d9b79888b804073ad6
https://audiophilestyle.com/forums/topic/54748-optimising-network-adaptor-settings/
Wonder if anybody also try this and get the same result. More softer treble, airy, not as forced....
Burnin in the AfterDark Constellation Gieseman X1 Ethernet Adapter. Music is very upfront, literally feels like it should burnin for 2000hours. I cant say if it also the new LHY LPSU80VA which powers the card and the jcat. The whole setup is almost new, alot of burnin is awaiting, but those changes did make some difference, can´t decide if its better.
I stopped believing anybody before first hand try. It looks like a great streamer and it is probably a upgrade, however your ears will decide. Its sounds simple but it is really hard to understand until a lot of money has been wasted because of other peoples thoughts and opinion.I sold my Cambridge CXNv2 audio streamer and have ordered the EverSolo DMP-A6 MASTER EDITON streamer/dac.
I hope i will hear an improvement in the network streaming . It gets great reviews on YouTube.
Do you think the upgraded clock and op amps will make a significant difference in the digital streaming SQ vs the original edition? I am considering the Master edition as well, but already stream to very high quality clocks (Denafrips Hermes DDC and Venus II DAC). Do the upgraded op amp chips in the unit affect only the analog output abilities of the unit (that is what my primitive understanding is leading me to believe)?I sold my Cambridge CXNv2 audio streamer and have ordered the EverSolo DMP-A6 MASTER EDITON streamer/dac.
I asked the store i ordered it from about this and they thought it only affects the analogue output abilities.Do you think the upgraded clock and op amps will make a significant difference in the digital streaming SQ vs the original edition? I am considering the Master edition as well, but already stream to very high quality clocks (Denafrips Hermes DDC and Venus II DAC). Do the upgraded op amp chips in the unit affect only the analog output abilities of the unit (that is what my primitive understanding is leading me to believe)?
That's pretty much what I figured...that the Master Edition upgrades mainly affect the analog output part of the equation. Even though I have an external DAC that is perfect my system, I do not know what the future may hold as I head into retirement. Having an optimized internal DAC in the DMP-A6 may come in handy in the future and be worth the extra $400 now. Thanks for the information!I asked the store i ordered it from about this and they thought it only affects the analogue output abilities.
And recommended me to get the cheaper version if you have an better external dac then inside master edition.
I dident want to have any regrets and thought it is nice to have the best parts inside for the internal dac. And also the gold design looks nicer, some times that can be importent to imo.
Maybe some of the diy tweakers in this thread could answer it better if you find some internal pics of unit which i dident find last time i googled.
Sometimes it can also be nice with different flavours. And the shortest signal path might be a thing also in favour of the internal dac.That's pretty much what I figured...that the Master Edition upgrades mainly affect the analog output part of the equation. Even though I have an external DAC that is perfect my system, I do not know what the future may hold as I head into retirement. Having an optimized internal DAC in the DMP-A6 may come in handy in the future and be worth the extra $400 now. Thanks for the information!
The most sensible thing to do would just be to use optical isolation, ie: a couple of fibre converters, with the one on the music server end using a low-noise PSU.I’ve watched several YouTube tutorials where folks have 3 to 4 network switches in cascade with basic ethernet cables between their routers and their music servers. When do you know that the internet signal has been reclocked enough to make a substantive difference? Is it all about what how resolving one’s system is?
@bpcans is right asking, as network transfers are asynchronous, clocking is not an issue. The way network devices can affect quality are ground loops and a burst character of a load on the receiver power supply. It create a noise on the end of the fiber link. It is why advanced systems offer special network protocols for audio transfers.The most sensible thing to do would just be to use optical isolation, ie: a couple of fibre converters, with the one on the music server end using a low-noise PSU.
If you really want to play with Windows 10 try the NTLITE. It could be interesting...or take the short path = Windows Server 2022. Its a galaxy in speed difference. Just better!.Aurally, it probably falls into the realm of "it varies person to person/system to system, try it and find out." You could always run the experiment and just keep adding switches until you can no longer hear a change.
...and now that the subject's brought up....I do have an open 12v rail on the lps powering one of two switches...hmm....
@OCC7N I'm still adjusting to some pc hardware changes, so I can't isolate the impact of those network tweaks on their own. That said, I'm not complaining about the sound right now. The other thing I've been looking into more heavily is reducing the # of processes and threads. This thread has some good info if you haven't seen it already
