audiobomber
Good for you! Maybe you can convince your engineering friends to actually listen instead of just quoting techy scripture.I don't like you...I have now lost all credibility with my engineering friends. Yes I did replace the SMP (with an ifi unit) on my wifi bridge that's connected to a switch that goes into my audio network bridge that is outputting via toslink to a dac, and I heard an improvement in sound that absolutely should not have happened. I was using DLNA protocol which does parity check to ensure bit perfect transmission. I have no explanation of why I heard a difference.
May I ask why you use Toslink to your DAC? There is a definite hierarchy, when properly implemented:
USB and I2S better than coax, coax better than Toslink.
