Cheers for the recommendation - I have that and the Neotechs (both OCC copper and the silver) in my Audiophonics cart for a while there, both have a bunch of positive buyer reviews.
@OCC7N I think part of the objection from some folk re shielding is around the potential for ground loops and/or transfer of noise over the shielding if it is connected at both ends. With the best of both worlds being using shielding but grounding only at one end (this might've even been discussed recently on this thread, can't recall).
Which funnily enough is what I just experimented with with some '3k' carbon fibre sheathing from AliX. Well the shielding was floating, not grounded at either end I realise, will need to make an effort to extend the foil to the ethernet RJ-45 plug outer copper ground). Cables tested with:
- an unshielded cat 5, a highly shielded Amazon Cat 8, a Furutech LAN-8 NCF each connected to an Ifi LAN iSilencer, the iFi on the feeding into my LHY switch, one cable from my server, the other from an FMC - one of a pair connecting to the router etc
- a generic DC-USB cable used here: Topping P50 LPS > DC-USB cable > iFi DC iPurifier2 > downstream (closest to LHY) FMC.
Some nice improvements for all but the Furutech where it was marginal. And apart from the too short lengths (I only had a 3m length, so had to make some calls) I reckon they look a bit cooler too. Will try on a few more cables including XLR interconnects and clock cables.
All in all pretty happy with my carbon fibre shielding experiment/proof of concept, I shall be getting a bunch more.
(This should probably be over in the AliX cables thread, but what the hey..)
