Understood, and I should have clarified I meant ethernet in & out of ER, with fibre only between the LHYs.The problem is that the fiber port on the ER is on the A-side. Running the ER as designed, A-side source, B-side to the end point, sounds best.
Lots of possible combos to try was simply my point, and sometimes the best sounding one is not the most intuitive.
Another possible chain is:
Modem/router > LHY FMC > fibre > ER > ethernet cable > SW-10
And the one you suggested of course which I think @Tubewin may have tried just now and found his chain sounds best with ER at the end (which I take to mean just before the server).. correct?
Modem/router > LHY FMC > fibre > SW-10 > fibre > ER
I really think you should try inserting the ER via fiber from the SW-10.
