I would like to read more, can you suggest me more links about it?
1- I cant find any guide for et1000/ n1000 amo
2- how to mod SRD amp to have a bias connection or create this amp by myself
3- how can I measure the bias voltage (between which pins), so I could decide if the amp working fine before I connect the headphones {or to know if this headphones fit to this amp}
again, thanks for the information!
I was amazed on my SR-40 that it's sounds only from one connection on it (without use the the - side of the cable)
I understood that the bias turn on the magnet on electrostatic headphones,
Soo if I connect the electrostatic headphones to SRD amp then it's may works a little bit but still not strong and good enoth.
ET1000 is electrostatic headphones they have connection to the electricity
the fuse of 32mA 240v is blown and for this moment I not having the replacement.
I searching for information about this item (n1000) because I think that there are more things to fix inside
{or maybe I will order another headphones in the futur that will use this or SRD amps}
https://i.imgur.com/xiDBmgU.jpg
Can another amp for cheaper price run Stax electrostatic headphones?
