HarlanDraka
Previously known as HarlanDraka81
I just bought the dx90 and it's just amazing, it dominated the dx50, anyways, I see it has the same *low/mid/high* (gain) setting, I never understood*gain* in sound, all I notice is that it makes the sound louder, just like pressing volume +, can someone please explain me the *gain* setting and what the difference is versus volume management.
I love the dx90, also I see there are custom firmwares, where do I find the latest versions or what is considered the *preffered * version?
The Gain amplify the signal from the source. If you have low impedance IEMS you can use Low gain.
Firmware: I tried 2.2.0 stock and yesterday i installed 2.1.8L0 (Lurker). I prefer the 2.1.8L0 with my Shure Se846. Which firmware is the best? It depends on how you like music and your headphones. You should try the different firmwares and see which one you like the most
