Strangelove424
- Apr 4, 2012
Thanks Woody! Sorry about the confusion, I missed ironmine's original post. Just made the correction.
Exactly the later... crashes when making initial adjustments/settings and always goes down when I try to set and save a user preset. Never happens while playing. How do you save the preset before it crashes?My computer with SlickEQ is on Windows 7 64 bit. Does this crash happen during playback, without the VST's gui open or while making changes to VST's interface? I know that VST 2.4 can have some issues with VST interfaces and crash when making adjustments. Once the preferred settings are achieved, and the interface is closed I have never had a crash from sound processing only.
WIN10 (see sixth post above for more details)For Mac?
Thanks for the info. Would MathAudio Room EQ work as a system-wide EQ solution for streaming music, like the Equalizer APO tool? It looks to be a standalone solution for Foobar playback, but maybe not the right tool for a complete system for all sound sources.I have lots of experience with Room EQ Wizard. I used it for several years, successfully, for Digital Room Correction (DRC).
I even bought a calibrated USB mic for $75 - MiniDSP Umik-1.
The REW program may seem intimidating at first for new users, though. But you can do it.
Once you generate the impulse file, load it into the Foobar component called "Convolver", the result is great.
But, if you wish, instead of this Convolver, you can also load the impulse into other convolution plugins. I used one time LiquidSonics Reverberate LE.
Or, Voxengo Pristine Space.
But, frankly speaking, then I found another (better) program: MathAudio Room EQ. It can accomplish everything that REW can do, but it's more simple, graphical, user-friendly, etc., and you can adjust it even while playing music. Once I tried it and compared to REW, I started using MathAudio Room EQ.
It can both measure the room resonances and correct for them (it has two modes).
I use it as a VST plugin in Art-Teknica Console with Foobar. But it is also available as a Foobar component, if you prefer it this way.
I advise those people who are new to DRC, start with MathAudio Room EQ. It will be most likely all you need.
How about adding system wide DSP options? I have multiple sources and I want them all to be processed, not just iTunes.
the automated system is indeed limited to speakers. but once you have a grip on how to use at least part of REW and a mic, I bet you will also start fooling around measuring headphones and IEMs with some DIY settings and "coupler"/dummy head...I personally use apo equalizer that works with any windows application.
https://sourceforge.net/projects/equalizerapo/
I'm also ordering a microphone to run the Room EQ Wizard (REW) and will feed APO with the result, but that approach is restricted to speakers.
I didn't see any export option, you'd be better off with impulses to use with EQ APO. still MathAudio does seem to be intuitive, so maybe some will want to use a virtual cable and a VSThost to make a system wide solution while using VSTs.Thanks for the info. Would MathAudio Room EQ work as a system-wide EQ solution for streaming music, like the Equalizer APO tool? It looks to be a standalone solution for Foobar playback, but maybe not the right tool for a complete system for all sound sources.
Yep, exactly what I have faced as well. Hopefully between us all we can figure out the work around. CheersUnfortunatley, there's issues with some VST interfaces and the VST 2.4 Adapter. I haven't used presets on SlickEQ, but after trying just now I found it crashes on me too. It's annoying for sure, but I haven't really needed user presets on this plugin due to the relative simplicity of it.
I noticed that under SlickEQ's preset settings there is a link called "open containing folder". I thought maybe we could create manual setting files in notepad or something and stick them in there, but when I clicked on "open containing folder" it crashed again. Then I realized I never did a full installation, and never created a new folder. Perhaps the SlickEQ dll is calling for a folder that doesn't exist. I'm curious if this might be a reason for the presets crash, but not sure. Perhaps using the installer for SlickEQ would create this folder, and retain preset functionality. I will try to trouble shoot this on another computer later.
