zeroxevo
- Aug 4, 2013
Thanks Acrylic is easier to work with but less forgiving that wood.
My first, and so far only attempt at a stand. Extra pine planks in the garage, so I thought why not? Its meant to look like Yggdrasil, the tree of life in Norse mythology. Best I could do with a jigsaw, a pocket knife and a drill. It could use a few coats of poly, though.
Hey zeroxevo do you have any tips for working with acrylic? (mainly smoothing the edges after you cut them and polishing the surface) i have a piece of scavenged acrylic from an old computer so might as well give it a try haha
Me too, nice job!I'm impressed, and I'll take one please =).
If you are going to cut the acrylic, you would need to choose the appropriate cutting tool. Anything above 5mm would need a scroll saw. If you are using thinner sheets, you can use a frame saw to cut out the intended design. Go slow, too harsh/forceful may crack the acrylic.
For smoothing edges u can use any aluminum oxide/silicon carbide sandpaper. I think you can get them from any DIY stores. The grit size I choose to work with are (coarse to fine) 36, 100, 180, 500, 1000 finish with 1500
You can sand down the rough edges with the 36 slowly work your way up to 1500 to get a very smooth finish. If you work on designs with many straight edges, you can actually use an orbital sander with the same grit size as above to smoothen the edges. It's saves a lot of time and effort. Alternatives dremmel with circular sand pads and commercial diamond edge smoothing setup.
Finally to buff finish. I use a car polisher (I do not own a cloth disc buffer). So I basically put it on the ground and use my feet to keep it in place and buff the edges with normal car polishing compounds. Repeat till you get the desired shine.
Hope this helps
Great idea, do it up!I am thinking of starting a thread for constructing a headphone case/carrier. What do you guys think?
I am thinking of my first project using black polycarbonate 4mm to reduce weight. 4mm should be enough to withstand 250kg of crushing force or maybe about 10,000 G of shock if i pad it properly with neoprene foam.
Comments?
Comments?
