Lohb
I think they could have easily shrunk down the size and have the same performance by using a thinner housing.
or maybe a bigger battery is in the works...
This thing sounds.. Amazing!!! I feel like Harry Potter lost in the maze except the maze is made up of sound. So immersive and magical, I completely agree with what everyone has been saying about this amp.. the detail, the soundstage, the impact from the bass boost.. all incredible. Through plenty of research I think it's safe to say that I couldn't have made a better choice for a first amp
That shipping cost is nonsense. Have you tried to see how much the shipping cost would be from Mouser or Digikey? I don't know if they ship internationally but it would be a worth to try.
Further update - so I've burned in the ADA4637-1BRZ for about a day now and I just have to say - Cayin should consider these in their next amplifier. The LME49600 is a very capable output device and is the reason I chose to buy the C5. The only thing I don't like is the aluminum case is pretty thick in comparison to the internals. I think they could have easily shrunk down the size and have the same performance by using a thinner housing.
Guess this is the correct AD OPAMP.... just double-checking as there were 3 or so variations...
http://th.mouser.com/ProductDetail/Analog-Devices/ADA4637-1BRZ/?qs=sGAEpiMZZMvtNjJQt4UgLalm6EXZly%2fyNysNWiYmVSw%3d
Thank you very much, I saw your suggestion and the contents of the DIY, and I think I willsoon to test this result, please wait, because need a little time to buy.
Need to note is that the sound is subjective, which requires an evaluation and a moresamples to determine the thing, now I can't say more likely, however, I can't wait.
On the size and thickness of the problem, yes. Thank you for your suggestions, this is a step in the right direction.
Yes, these are the correct ones. Please be careful when you change them out, they are very small and also surrounded by other components. It would be very easy to ruin the amp but someone who has experience with surface mount devices should be easily able to do it.
If I may suggest as well, respectfully, that the plastic (ABS?) end is prone to breakage and scratches.
Perhaps an all-metal enclosure might be more suitable, especially since this is designed for use as a portable.
(I do think it's a really fine sounding amp.)
I took off the front plastic end. Looks better.
