Andricop
- Nov 12, 2010
I ordered through Jaben Singapore but you can order directly from their website also
Got it. Thank you.I ordered through Jaben Singapore but you can order directly from their website also
For you it would be better to order from Musicteck. You avoid the Customs headacheGot it. Thank you.
Here's what I wrote comparing Orpheus and Yatano 8w to a fellow head-fier some time ago. I heard the same trend while comparing these cables on Jewel too. I only have the lower grade Rh2+ of the 4w equivalent. It dials back one notch on resolution, top/bottom extension, and note weight.Could someone who has any of the high end brise cables; Yatono 8w/4w etc discuss what they do to sound and if you have paired them with Jewel discuss the pairing. THANKYOU
Same. What's the different between a BSEP vs Yatono 4w Ultimate for Z1R?Whoever owns the Yatano Ultimate 4w and wants to comment on there experience, It would also be super beneficial. I am itching for one of these but would love more data points.
Must be why I love the cable so much xD I think with highly resolving iems Yatono 8w really excelsHere's what I wrote comparing Orpheus and Yatano 8w to a fellow head-fier some time ago. I heard the same trend while comparing these cables on Jewel too. I only have the lower grade Rh2+ of the 4w equivalent. It dials back one notch on resolution, top/bottom extension, and note weight.
Compared to Orpheus, Yatano 8w has better subbass and slightly reduced midbass. Yatano also has more upper mids/lower treble energy which gives a sense of clarity compared to "slower and rounded" Orphy. To me, Yatano is the ultimate "flat" response cable and Orphy is the "musical" counterpart.
The tricky part to explain might be the blackness. I think Orphy gets the sense of blackness not only the shielding but also from reduced upper mids. A bit like how Traillii has the upper mids turned down. Cymbals, hihats, snare drum spring resonance, and shhh-sound are slightly pushed back. When I first switch to Yatano 8w, I get the impression that this cable is busy sounding because nothing is held back. I listen to Dream Theater's "Take the Time" and I immediately notice top end splashes of the drum kits and edges from the guitar/vocal coming forward. This makes it sound busy and less black because you don't get the sense of separation like the Orphy. But with this understanding, if I listen carefully, there is still a tremendous amount of depth and separation with Yatano such that I consider it "as black as Orphy" if not more. Also, the "busy" presentation makes the 8w soundstage closer and upfront, compared to Orpheus.
With prog/metal, I actually strongly prefer Yatano for its speed/edge/balance/detail. For small ensemble acoustic Jazz, I might chill with Orphy.
Bsep is literally designed to bring out the best of z1r at least that's what it says so I'd probably buy it over Yatono if you are planning on only using it with z1r also a lot cheaper.Same. What's the different between a BSEP vs Yatono 4w Ultimate for Z1R?
I have an opportunity to pick up a 4w ultimate for really good price. The only issues is that it's mmcx and I prefer 2pin. But if BSEP works with Z1R I may have to take a look.Bsep is literally designed to bring out the best of z1r at least that's what it says so I'd probably buy it over Yatono if you are planning on only using it with z1r also a lot cheaper.
I am selling a 2pin Yatono ultimate 4w btwI have an opportunity to pick up a 4w ultimate for really good price. The only issues is that it's mmcx and I prefer 2pin. But if BSEP works with Z1R I may have to take a look.
PM'dI am selling a 2pin Yatono ultimate 4w btw
BSEP for Z1R is supposedly a Yatono 4W with a Murakumo shielding.Same. What's the different between a BSEP vs Yatono 4w Ultimate for Z1R?
