choisan
can you believe US600 to re terminate from mmcx to cm? can't believe it
i have recently asked how much is the retermination fee for a yatano 8 from mmcx to cm, guess how much it is? you will be surprised.
the cable is out of 12 month warranty
Jesus... i knew its screwing expensive but didn’t know its THAT expensive...US$600
I think their connectors are all self developed and contribute to a significant portion of the cable’s cost.I wonder why it costs so much to re-terminate the cable
That's what I thought. In that case, making the cable from the ground makes more senseI think their connectors are all self developed and contribute to a significant portion of the cable’s cost.
Also instead of just cut and connect, they actually reroll the cable and redo the shielding so its quite a lot of work
it won't give you 30% off from the srp.I think their connectors are all self developed and contribute to a significant portion of the cable’s cost.
If you consider the low price of OFC cable which is brise using. All the cost of the cable is come from plug, shielding, solder and labour(tuning, QC). Then the cost of re-terminate is more understandable.I wonder why it costs so much to re-terminate the cable
Do you have any guesses?
I need those IEM stands...Bought 2 UPG001RH+ last week. God they’re good.
good luck.
i got my 3rd brise audio collection, which is a yatano 8.
with 4, i can hear a more separate detail of musical instrument and detail and with 8, it gives more depth.
as a result, i sold my effect audio janus b from my collection
