i received Tanya and can confirm it is superb.
Tanchjim in ear monitors Impressions Thread
- Thread starter FastAndClean
AmericanSpirit
Member of the Trade: Night Oblivion
Placed order for Tanya, but it’s shipped with 4px probably would take a month but looking forward for bullet type of Tanchijim! So far my best bullet IEM experience is Final E500 for 2021. Hope Tanya is another neutral reference bullet type. Not a typical v-shaped.
[Edit] just scrolled back few posts and saw measurements, wow! The pinna gain is spot on my personal target 3.1khz. Good ringer for HTRF spot hitter.
It is.. it is superb!!!Placed order for Tanya, but it’s shipped with 4px probably would take a month but looking forward for bullet type of Tanchijim! So far my best bullet IEM experience is Final E500 for 2021. Hope Tanya is another neutral reference bullet type. Not a typical v-shaped.
Layering is crazy at this price. This could probably redefine the price bracket. The graph shows a massive bass but it is actually more like neutral with bass boost. Really surprise on how the bass doesn't interfere the mids. Very well controlled. Big well done Tanchjim for this price and this performance.
How does it compare to Final E500?
Oh and since it has a non detachable cable, is it microphonic?
TooPoorForHiFi
Previously known as MidNighTempest
Any amount of driver flex when inserting into your ear?i received Tanya and can confirm it is superb.
Didnt A B yet but so far i think Tanya outclassed E500 technicalities. The layering is noticeably very good in Tanya.How does it compare to Final E500?
Microphonic, not that i expect yet.
Not at all. Vent located at the bottom of the nozzle. (Right before nozzle)Any amount of driver flex when inserting into your ear?
redrol
I've never been so excited for a 20 bux IEM!! Tanya <3 <3
Hello!
I was looking for IEMs with a good sub bass and bass. Can somebody compare Moondrop Blessing 2 Dusk vs Tanchjim Oxygen vs IKKO OH10.
TooPoorForHiFi
I believe @Precogvision might be able to help with this one.Hello!
Hello!
Yeah, sure thing. Are you just looking for bass specifically? If you want a good balance of everything and want the most technical of these IEMs, then I'd just go with the Dusk by default. It really can't be beat on paper.
Now, if we're talking about bass specifically, the Dusk is the most sub-bass oriented of these IEMs, so it'll be the cleanest. The tactility of the bass itself, however, is not as great. It sounds fairly dry. The Oxygen doesn't sound as dry, but it doesn't have much slam; I don't think it has very remarkable bass in general. Overall, I actually think the Ikko OH10 has the best bass tactility of these IEMs. Again, this is just if you're looking at bass specifically. Outside of this:
- All three of them are upper-midrange oriented with the OH10 having the most presence in that region; it's inherently the type of tuning that's going to play best with stuff like K-Pop and similar genres. The Dusk is the best tuned here to my ears with the Oxygen following behind.
- The OH10 has the best treble extension with a strong peak at 15kHz. Depending on the extent of your hearing, it may or may not sound dark anyways because of this. The Dusk's treble is quite linear and smooth with a small bump at 6kHz; the Oxygen has a tad more energy in the lower-to-mid treble for a more spicy presentation.
- Technicalities go Dusk > Oxygen > OH10.
Hope this helps
Thank you! I really appreciate your help!Yeah, sure thing. Are you just looking for bass specifically? If you want a good balance of everything and want the most technical of these IEMs, then I'd just go with the Dusk by default. It really can't be beat on paper.
Hope this helps
thanks for the early impressions. Been eyeing the Tanya since it was announced and finally ordered one this morning from shopee. Still haven't seen a ton of feedback on it yet other than a few Chinese reviews, so it's nice to see someone here liking it.Didnt A B yet but so far i think Tanya outclassed E500 technicalities. The layering is noticeably very good in Tanya.
https://zhuanlan.zhihu.com/p/369448160
This is one of the reviews I've read. Seems promising for the price. I'll try to translate a bit in case google translate doesn't work well. My Chinese is rather rusty, so if anyone spots any mistakes, please help correct.
"Based on the frequency response curve and my own listening experience, it's a pair of earphones that fits the Harman target. The mids and higher frequencies are relatively balanced, and it has a slight biased towards the lower mids. Using the "bass" tips will give you the thumpy bass that people usually like, and using "treble" tips will bring out the higher frequencies. For a pair of earphones with balanced tuning, it's really easy to tweak the tuning. Depending on the tuning that you want, you just have to choose your source and ear tips. For those without a better source, just changing ear tips will do. I personally prefer the listening experience that I get from using the "treble" tips, but I did test out the "bass" tips as well before I came to the conclusion that the Tanya's overall tuning is relaxed and natural sounding, which is in line with their marketing material. After going through a ton of songs, there is very little sibilance, and the sound quality is not going to punch way above its price point, but it is probably still slightly better than its price suggest. Resolution isn't good enough to pick out all the details, but it's not really that muddy either. Vocals are forward sounding, but not in your face. In life, it's a happy thing to have a friend who is close to you, but still knows how to give you enough personal space. Using that analogy, you could say the same with the Tanya as well.
As a pair of earphones tuned to the harman target, I think it could be a great transitional product for folks just getting into Hi-Fi audio gear. By playing around with the tuning using the ear tips, you can try to figure out you own personal preference for tuning. However, if you already know what you like, and you're not a fan of this relatively balanced tuning, you might want to go with other options."
redrol
I did actually test the O2 with 15k treble.. which was like a laser beam into my brain. It's got more energy here than almost anything else. Also it's not high-mid focused at all. The mids peak 2-3k and dip after that... not what I would call high mid focus. As far as bass slam.. lol, O2 has a lot. Go figure. Different ears I guess.
Aint no high mid peak here..
aspire5550
- May 30, 2015
yo bro, stay safe in malaysia.i received Tanya and can confirm it is superb.
May I get some comparison between tanya and blon bl03?
Thanks!
Hey thanks. Where you from?yo bro, stay safe in malaysia.
Thanks!
I dont have bl03 unfortunately. I have Final E500. These two sounds pretty different. E500 is more balance. Tanya is toward neutral bass boost.
Total: 6 (members: 0, guests: 6)
