Sito Lupion
- May 14, 2016
Great, kindly share your impressions, once received
Try to compare bass with Meze 99 Classics
After a few hours of burn, can say that these headphones are wonderful. It will be difficult to find some for 79 euros that sound better.
They are very comfortable and the materials leave you surprised with their quality / price ratio, my friends seeing the presentation with their small suitcase were surprised.
the bass are great, good definition and stuck, no need to open their tabs, For the basshead, with 1 opening can be enough, 2 ruin the sound too much.
the basses of the Meze are more forceful due in part to their large subwoofer, but they do not have the detail of the pro 82. I suppose that the wooden cups also influence the result.
the two headphones have great punch.
FIIO E17 didn't sound too good with Pro 82, I hope you have better results with E17K. Using Coax input will probably net best results.
Still I'm betting on MF-V90 HPA sounding better with Pro 82.
Don't forget to buy the tuning foams:
Thin & Thick Inside Foam Disk Ear Pads For HD545 HD565 HD600 HD650 Headphones
Thin & Thick Inside Foam Disk Ear Pads For K240 K241 K270 K271 K272 Headphons
or
https://www.aliexpress.com/item/Thi...-HD565-HD600-HD650-Headphone/32601752052.html
https://www.aliexpress.com/store/pr...0-HE300-HE400-HE400i/2961104_32824443199.html
You are right Benf, they do not get along very well with Fiio, everything sounds more consistent with the MF.
...to put some snag, at high volumes, can get to fatigue due to its brightness, but there is no hiss,
I hope to fix it with the foams mod.
