HA200 Will drive susvara vert well. Take a look here at 11:32.sorry my wrong typing, i think HA200 is NOT suitable to drive Susvara and 1266 TC
T+A Solitaire P planar magnetostatic
- Thread starter thinker
soundofsingle
soundofsingle
No adapter!The Ha200 can be used as preamp with the 4 pin XLR output at the front.
https://shop.ta-hifi.de/de/kabel/verbindungskabel/4-pin-xlr-zu-rca-adapterr-ha-200-4663-99101
ThanatosVI
You have both the DAC200 and HA200?No adapter!
soundofsingle
Yes sirYou have both the DAC200 and HA200?
Happy to report that I finally grabbed a great silver cable, the Prion4 from DHC for my Sol P. Peter from DHC confirmed that the Eidolic HD800 connector won't work with the Sol P, and the wide gauged cable couldn't be fit into the slim original HD800 connector.
The solution Peter came up with is a super compact but elegant adapter from standard 3.5mm to the HD800 connector, it's wired with naked large gauge silver inside according to Peter. It fits into the deeply recessed seat of Sol P perfectly and works like a magic.
Hey all. Was wondering if anyone has tried the SolP out of a DX300 Max? And if so, did you find it sufficiently powerful to drive the SolP well?
ThanatosVI
The Solitaire P is quite efficient, so chances are good that it's powerful enough.Hey all. Was wondering if anyone has tried the SolP out of a DX300 Max? And if so, did you find it sufficiently powerful to drive the SolP well?
Can't say anything about the synergy though
FooFighter
I know @MatW does have both DX300 Max and SolP but he's on a forum break for now
ThanatosVI
Maybe he wrote impressions in the past, the search engine might be able to dog something upI know @MatW does have both DX300 Max and SolP but he's on a forum break for now
If a new toy has to come, have you considered HiBy RS8?Hey all. Was wondering if anyone has tried the SolP out of a DX300 Max? And if so, did you find it sufficiently powerful to drive the SolP well?
These two had something special with this pairing:
Se tu m´ami by Akiko Nakajima on Qobuz https://open.qobuz.com/track/7401549
At first listen it was even disturbing that Akiko's sound was moving between 10 o'clock and 1 o'clock - I suppose it it because singers tend to move upper body around. Amazing example of stage and pinpointing focus .
A Moment Apart by ODESZA on Qobuz https://open.qobuz.com/track/56729339
This is just energetic with a good amount of deep bass, a recent found for me.
RS8+Elite is also awsome.
Ragnar-BY
ThanatosVI
16.8awg also still fine.How thick is DHC Prion? 18AWG Arctic Cables Magnus was absolutely fine:
Should be 18.8 awg, but the sleeves make it even thickerHow thick is DHC Prion? 18AWG Arctic Cables Magnus was absolutely fine:
ThanatosVI
Getting ready to move. Storing away all my gear.
My cat is keen on supporting wherever she can.
meet the T+A Solitaire C(at)
Total: 14 (members: 4, guests: 10)
