ThanatosVI
Looking forward to your impressions then!One of the first T+A Wireless HP will be mine
Pls also share your listening impressions vs stock.Received my Grand cable from @lavricables
Amazing build quality, matches the quality of the headphone way better than the stock cable.
Really great ergonomics too and doesn't drag the headphone down, yet it's build like a tank haha.
Nice!Solitaire P finally arrived and now burning in...
Interested in some examples of PEQ settings for raising the upper mids dip.
Can you share your settings?
Also I failed trying to spontaneously change the pads against the wide models according to the included manual and didn't want to destroy anything - will need to check previous posts again
HiI tried to create a template EQ profile for Solitaire P, using the Pro Q3 VST3 plugin on JRiver Media Center. I used the slope parameter (dB / oct value in the screenshots, which creates the flat bell tops). It can also be applied to PulseEffects parametric EQ on Linux, which also can modify the slope.
You can disable the 4th point, if you like but I wanted to tame the treble a bit more. Just to be on the safe side, I tried to the keep the 9-10 kHz region flat, then a constant rise for the air frequencies and the 5th point is exactly for that which can also be disabled (closer to flatter D8000 air frequencies). The bass performance is for me perfect, so nothing there.
I tried to keep the tonality unchanged with thicker mids but add a little bit of air and mid clarity. It improves the piano sound and vocal clarity. But a bigger bump in the upper mids / treble region might make, for example, the drum bell sound too disintegrated from the rest, so kept the change subtle.
Here are the single EQ settings from left to right:
It should be OK. I was using another PEQ which is actually a studio grade VST plug-in (FabFilter ProQ3) and it has more fancy features. The standard Roon PEQ should be good enough.Hi
Don't know if anyone else has tried the previously posted eq settings using a standard PEQ software like Roon?
Am only able to specify peaks and highshelf but no slope parameters to specify flat bell tops?
Anyways it's still burning in and maybe yet to early to experiment and expect stable results.
For now I am enjoying Roon-HQ-Player with poly-sincgauss-hires-lp filter in PCM mode and quite satisfied with the result.
For sure a better Swiss knife for my all-day-listening purposes and getting a satisfying bass response without need for equing and overall a non-fatiguing signature.
Straight IPAD to Holo Audio Spring 3 NOS with Apple Music sounds really nice too, e.g James Blake "The Wilhelm Scream"
Very nicely sharp rendered holographic stage, object positioning seems to be better identifiable than Susvara.
What a nice dry punchy bass response - it's indeed close to TC in that regards without needing to fiddle around with the frame.
Thx mate!It should be OK. I was using another PEQ which is actually a studio grade VST plug-in (FabFilter ProQ3) and it has more fancy features. The standard Roon PEQ should be good enough.
Then maybe you should already grab the DCA Stealth. Since then I didn't even feel the need to check anything else. It is not the fun technical bass master the Solitaire P is, but "the" headphones that is from design to sound that is the next level of everything.Thx mate!
Funny that I finally came to your suggestion for nice headphones 1 year later and now you don't even have the headphones any more
That roughly how much I used them before selling them to RoastyRight now I might have only like 8-10h of playback on them...
