bwcgrx
Now I see the gustard H10 for about $300 on massdrop, now I should get that over the lycan right? Also switching out that op-amp with bursons.
I have both amps and they are each excellent. However in the $300 range I'd say that the H10 is the better amp by a considerable margin. I snagged the Lycan for about $160 off ebay new in box from an individual, not Supreme Sound, and at that price it is beyond excellent. The H10 is overall a much beefier amp in physical size, build quality, and overall sound quality. If you thought that regular op amp rolling was in your future the Lycan would be a better choice as it only requires one dual or two single op amps and access for swapping is much easier. I'd check out Supreme Sound's Ebay listings for a demo model at considerably less than the direct asking price. The Gustard to my ears has an overall smoother presentation and seems to have better control especially with bass response. I'm on stock op amps with the H10 for now and plan to upgrade to full boat V5 op amps next month once Burson has the new H10 safe 17v rated op amps ready to go. Either way you can't go wrong as both amps sound fabulous but again if you are going to spend in the $300 range I say go for the H10 as it is overall a fantastic sounding and very balance amp.
