Originally Posted by Chri5peed /img/forum/go_quote.gif
Anyway, it is an engineering principle, more often than not a bigger item will do a better job over an identical, but smaller one.
Yes, this is why ibuds sound so much better than high-end canalphones, right? Diaphragm surface area (and its relation to air mass being moved) can control the threshold of bass reproduction, but there is a reason that tweeters are smaller than woofers and tend to be executed with a different diaphragm principle.
D'oh, its an engineering principle and I am an engineer. Not always, but a lot of the time, bigger things are better.
I am a electro-mechanic, got a degree in Electrical Engineering.
Well, I am a professor of design, and you're doing a disservice to engineering to use your profession to back up poppycock when you get called on it. Yes, bigger things are often better or at least it's easier to maintain performance with them, but we're talking about a specific design problem here for which the benefits and compromises of size are easily demonstrated not to carry the connotation you claim. Why not just back off on it, and say as an engineer yourself, you know there are ways around this problem. Then you'd be right again.
Originally Posted by Pantocrator /img/forum/go_quote.gif
Which do you think is better? First off, I am going to be using these headphones in college in a dormitory, so there might be some noise issues, and also i might use these in public where I do not want other people to hear my music...
Sorry your thread got so derailed. What most of us in your position end up doing is building up both a home rig and a portable one. With a good closed portable, a canalphone like the RE2 or a headphone like, say, an ES7, you'll be covered on the go. Then you'll be free to get a great-sounding circumaural for the dorm-room that can scale well with any later source or amp upgrades you get the urge to do. You can also afford to get an open headphone for the home set then, because you'll have a closed option for those times someone is trying to sleep within earshot.
But for what makes sense as a good choice in either case, don't worry about circumaural or supraaural, worry about your music preferences and budget. We know what your initial rig will be, so unless you're thinking of going for a real home amp and source someday, the best home headphones are all out. That doesn't mean there aren't still good options.
