- Jan 17, 2003
I've finally had the opportunity to listen the amp. Of the amps I've recently had in rotation, the Porta Corda MKII and the XP-7, I'd put the sound quality of the SuperMacro V3 somewhere between the two.
The PC lives in the midrange. Music is fluid and sweet but somewhat flat. There is little in the way of decay especially on the high end. Bass is tight but somewhat one dimensional.
The SuperMacro extends the frequency response. It adds bottom to the bass and adds some sparkle to the high end. It also adds a lot of dimension to the music, giving it the "air" that the amp seems to be becoming famous for. I guess this is what Xin refers to as "macro hall sound". It falls a bit short in that the bass seems to be strong and slamming but not quite as tight as I might like it. It's almost as if kick drums and other low frequency information have a touch of reverb added. The high end is detailed but is a bit "crunchy" and could be a bit smoother.
The XP-7 takes the small problems of the SuperMacro and irons them out. Bass is full, but tighter; highs are well represented but smoothed out without loss of detail. In terms of soundstage I think these two amps are about on par.
Keep in mind that a new XP-7 goes for $500, does not run off wall power unless you buy a separate $200 power supply, cannot recharge internal batteries, and is not anywhere near as portable as a SuperMacro. It is however a superb amp and for the SuperMacro to be this close to it, is remarkable.
Please understand also that these are brief impressions. I've listened to 2 cds and only used one set of headphones - the HD 25-1. The amp has had no time whatsoever to burn in, so bass may tighten up and the high end may smooth out a bit. However, "out of the box" the amp sounds fantastic and will probably get better with time.
