Super Stable! FiiO Low Noise Regulated Linear Power Supply PL50 Is Available on AliExpress Official Store!
Apr 7, 2024 at 11:30 AM Post #121 of 124
I'm using the PL50 with the FiiO M17. I have been generally first turning on the PL50 before the M17.
The first replacement fuse came with the PL50 and this second one is a slow blow fuse so hopefully it will last longer this time. 🙏
What size replacement fuse did you purchase? You can buy a slightly higher current. slow blow fuse is also a good option.
Apr 7, 2024 at 11:35 AM Post #122 of 124
I'm using a 5x20mm T1AL250V 1A, which I think was recommended by FiiO in an earlier post. Hopefully this one will have a long life. If not then I'll look into using one with a slightly higher current.
Apr 24, 2024 at 9:38 AM Post #123 of 124
