Thorsten Loesch
Member of the Trade: Studio RaumklanG, Studio Cocktail
I found the idea of Super (capacitor) charging solution is very interesting. Just wondering if you know of any products that are using it?
There are a few more "esotheric" products, I think the Chord Hugo TT used supercapacitors and a few others do. It's rare though. I used them on the digital PSU of the iFi iDSD Pro.
Without load, the voltage of my capacitor bank can go up to 5.45V. Usually, what's the maximum voltage these capacitors can handle without getting into trouble?
I think the ones you use are rated 5.5V. You might want to see if the power supply can be dialled down a bit, I would suggest 5.25V unloaded.
I am also considering a similar solution for my pre amp that use DC 12V (it comes with a DC 12V 1A power supply). Looks like most of these super capacitors are rated with 5.5V. Do you think a super charging solution for my pre amp (12V) make sense? If yes, could you suggest a way for me to built one?
As it so happens I have just made a Supercap block for a 12V DC product.
I used 12F/5V Elna Dynacap DU, which internally really are two 25F/2.7V in series and were available on the local e-bay as surplus for very little money 3pcs for the equivalent of 3USD or a beer in a bar). The 12F/5V rated unit has around 50mOhm ESR.
I used 9pcs in total for 3pcs in parallel and then 3 sets of the 3pcs units that are now 36F/5.4V in series.
This gives a block of 12F/15V with 50mOhm ESR.
I tested the voltage sharing extensively and I got each capacitor at 2V +/- < 5mV through a bunch of discharging/charging cycles. This capacitor block delivered 1A nearly 30 Seconds while discharging from 12V to 8V.
So that is how easy it is to make a 12V Bank.
Thor
