asymcon
- Jun 16, 2015
Hey fellow Sound Science lurkers.
About 2 years from now I acquired my first high impedance headphones, no other than AKG K240DF. The first listening made my jaw drop and I had to sit down - I was that blown away by the clarity, compared to K701 and newer K240 MKII. The only bothersome factor in the frequency response spectrum was 9-10kHz peak so I immediately opted for recabling with well proven Van Damme Miniature Starquad cable. I was more of a subjectivist back then.
Starquad is dirt cheap by audiophool standards, about $3/metre, but in contrast with all the uber-expensive junk, it's a well-proven cable frequently used in studio environment and built to last (another reason for recabling). As usual I terminated the negatives at the end (near the 1/8" TRS).
Suddenly the headphones came alive, the bass had more presence and the peak was gone. This shouldn't be happening with 600Ohm drivers, right?
Fast forward one year into Jan-2016, I still love my K240DF, but this recabling thing seems suspicious, could it be McGurk effect?
I purchased another pair (I wanted a backup anyway) and did side-by-side comparison. The difference was still there, with original cable the headphones suffered the issues above. I did extensive measurements of resistance and capacitance with DMM (Mastech MS8226), yet the Starquad actually measured a little bit worse (higher capacitance) open circuit.
Finally in Dec-2016 I did another test with my switchbox and found very noticeable difference when I inserted the stock cable in between the signal. Stereo separation was a lot worse, which I also confirmed with test signals (1kHz to the left, 500Hz to the right). To ensure the validity, I also invited some of my friends and switched the box without them knowing. And yes, they complained about the same thing.
To cut to the point - could any of you recommend me a testing method how to measure this difference?
I'm visiting a friend tomorrow who has decent Rigol oscope - what is needed to measure say capacitance and impedance of a cable over target frequency response? Can it be done with a regular oscope and only 8bit FFT?
Thanks for any input
